my new amp. what is this?
Old May 27, 2010 | 08:34 PM
19transam81's Avatar
[IMG][/IMG]
[IMG][/IMG]
what is this telephone cord looking cord go to? also my cousin who gave it to me never used it once. he claims that i will need to rewire my whole car to use this big of an amp. now, im not too sure about the rewiring of my car and getting a new alternator but... what do u guys think? is he crazy? im thinking about running 3 10s but im not sure if that will fit in the cobalt trunk. i cant measure the trunk because my car is on hte other side of town. i got the amp for 100$, good deal?
4000W Max, High-Current Monoblock Car Amplifier
RMS Power Rating:
500 watts x 1 chan. @ 4 ohms
1000 watts x 1 chan. @ 2 ohms
2000 watts x 1 chan. @ 1 ohm
Max Power Output: 4000 watts @ 1 ohm
Wired Remote Bass Level Control Included with Blue Illuminated Knobs
Also illuminates red to indicate when amplifier is clipping
High-Current, Non-Regulated Power Supply
Preamp Outputs
Cobalt Blue LED Illuminated Heat Sink Design (on/off switch for your preference)
Thermal Regulated, Air Induction Dual Cooling Fans
Double Sided PCB (Circuit Board)
High Gloss Chrome Plated Finish
Unique, Clean Chrome Fire/Flame Design
Blue Illuminated VU Meter Indicating Output Response
Clear Power and Speaker Connectors
Variable Bass Boost: 0-18dB @ 40-100Hz
Variable Low-Pass Crossover: 40-120Hz
Variable Subsonic Filter: 20-50Hz
Signal-to-Noise Ratio: 100dB
Frequency Response: 10Hz-40kHz
Phase Control: 0-180°
THD: 0.05%
Input Sensitivity: 200mV - 8V
1/0 or 2-gauge power and ground leads recommended when running amplifier at 4 or 2 ohms. We recommend 1/0 or 2 gauge power and ground leads when running amplifier at 1 ohm. Contact us for information regarding a discount on a select amplifier kit when purchased together.
Dimensions: 18" L x 11-15/16" W x 2-1/2" H
Old May 27, 2010 | 08:38 PM
donkeyballs's Avatar
wired remote bass level control your prob missing the box with the control knob..
Old May 27, 2010 | 09:07 PM
do i need it? the amp i have right now is an alpine m450 and i dnt have a bas knob like that...
Old May 27, 2010 | 10:22 PM
No.. you can adjust it on the amp.. Its nice to have it mounted on your dash for easy adjustment ..
Old May 28, 2010 | 12:32 AM
EmperorJJ1's Avatar
its an ok amp. not very clean and defiantly not 2000w rms but its will make a good 1200w rms
musifreak190
Jun 6, 2007 08:28 PM
xtrmsnd
May 21, 2007 04:04 AM
h0l0caust
May 8, 2007 10:57 AM
tricky1
Oct 19, 2006 11:47 PM
