Mysterious hid problem :(
Old Feb 15, 2012 | 06:54 PM
Blinker fluid's Avatar
Hey guys I've been in the hid game for quite some time never had problems. My 6k headlights are solid, but I'm running into problems with the fog lights. I just installed 3k hid kit in my fogs...no relay (I know..stupid, once summer rolls around itll go in) but they run fine for about three minutes, then the passenger side goes out, if I hit the fog light button again, they will come back on. Had this problem with a set of 6k's in them before too...any thoughts??
Old Feb 15, 2012 | 06:56 PM
Mike Casey's Avatar
happens with mine id like to know too
Old Feb 15, 2012 | 06:57 PM
BPacak's Avatar
Vtec Rep
i have mine in with no relay and they worked fine for months then recently the passenger one randomly goes out, then next time i start my car or turn the fogs back on it will work.
Old Feb 15, 2012 | 07:06 PM
DBlock's Avatar
QUEEF-NUGGETS
I think its a conspiracy cause my passenger side also goes out too
Old Feb 15, 2012 | 07:11 PM
ChevyRockstar's Avatar
Mine does the same thing, lol but it hasnt done it in a few months. I just bang the ballast a little haha
TommyP's Avatar
AWD > FWD
for some reason it's usually the passenger side that has these issues, idk if it's from being farther from the fuse box or what. A relay should fix pretty much all of these issues. Could just be cheap chinese hid components too.
Old Feb 15, 2012 | 07:15 PM
DBlock's Avatar
QUEEF-NUGGETS
Well mine just went out completely ...I tried two different ballast..and no luck
Old Feb 15, 2012 | 07:21 PM
chood711's Avatar
its my passenger side headlight that goes out
Old Feb 15, 2012 | 07:25 PM
SlowShifter's Avatar
Hmmm... wonder what it is about cobalts that there are so many pass. side issues. Mine has acted up for a year now. Blowing fuses and lights constantly.
Old Feb 15, 2012 | 07:27 PM
Dang!!! Haha this is common thanks for all the replies! Tommy, ya got me there, deffinately some chinese cheapies haha...don't grill me on this, well I know I'll get grilled. I'm not sure what amp fuse the fogs run on BUT....what if I bumped it up 5amps? So if it's like 10, go 15? Or will I arc flash and murder my car? The relay I got....doesn't seem long enough to reach to the passenger fog light bulb
Old Feb 15, 2012 | 07:35 PM
Have you checked your HID fluid levels
DBlock's Avatar
QUEEF-NUGGETS
Iirc the fog lights are a 15amp fuse
Old Feb 15, 2012 | 07:37 PM
TommyP's Avatar
AWD > FWD
don't ever up the size of a fuse. It's safer (and cheaper) to blow a fuse than to fry a fusebox. It's 10 fyi. I'd be surprised if the relay you got isn't long enough, I've never seen one that was too short, they're usually designed to work with trucks which have much larger engine bays. If all else fails just throw the stock bulbs back in, at least they're reliable.
Old Feb 15, 2012 | 07:50 PM
I just topped them off LOL, I will look into running the relay this weekend, where would the wire from the passenger side snake through? I wasn't able to find a good place
Old Feb 15, 2012 | 08:06 PM
TommyP's Avatar
AWD > FWD
run it through the same spot the factory harness goes through, then just run the harness down behind the headlight bracket.
Old Feb 15, 2012 | 08:13 PM
Tommyp....you are the man
Old Feb 17, 2012 | 12:27 AM
EmperorJJ1's Avatar
lol when did u get hids?
Old Feb 17, 2012 | 12:33 AM
CannonBalt's Avatar
Mine does it to the driver side
Old Feb 17, 2012 | 12:53 AM
breds2k's Avatar
this has happend to a few people i know and whenever this happens, mostly on dodges, i tell them if they wanna keep hids to do two things. Go to ebay and buy error cancelers, and get a relay. Never sure which one makes it work but it cant hurt.
my buddys 2009 dodge avengers low beam would randomly flicker off when driving! error cancellers did the trick without a relay!
Old Feb 17, 2012 | 01:01 AM
SunburstSS's Avatar
keeps happenening to me, **** goes out completely, i just bought a brand new kit, with a relay harness and im gonna hook it up to the parking lights that way they don't flash when i put high beams on
turbochargedss2012
Sep 20, 2023 12:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
Iceberg
Sep 28, 2015 01:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
