need help with 4 channel amp
Old Oct 4, 2007 | 11:17 PM
Joewit's Avatar
Does anyone know how to wire a 4 channel amp, (from the amp to the speakers) I've done my sub so I have the basic idea Im just not quite sure how your suppose to wire in regular speakers. And the amp is a punch 400 and the speakers are mb quart discus 6x9 and components with a alpine cda-9856 HU.
Old Oct 4, 2007 | 11:20 PM
halfj99's Avatar
well you know how to make the amp work. then just run speaker wires like you normally would to the speakers, its no diffrent then to a sub
just make sure you wire to the correct ohm which will be 4 ohm, meaning no bridging...and since you have a channel for each speaker, it will be 4 ohm, so your in luck..just run a positive and neg to each speaker
couldnt ask for an easier instillation
Old Oct 4, 2007 | 11:23 PM
Joewit's Avatar
see thats what i figured but the dude at the speaker store was telling me something about a 1 into 4 wire that you run to the HU instead of the speakers. I think I'll just do it your way like i planned to.
Old Oct 4, 2007 | 11:25 PM
halfj99's Avatar
yeah i have no idea what that guy ment, but this is the way it should be
Old Oct 4, 2007 | 11:29 PM
Switt23's Avatar
Just like a sub.
Terminal looks like this...
__1____2_____3____4__
____(A)_________(B)____
Plug your RCAs in for signal but take note which is which. What I mean by that is that your deck hopefully has an output for the front's and the rears. The Amp should have an input A and an Input B. Make A the fronts, and B the rears, the wire the Positives and negatives accordingly.
Old Oct 4, 2007 | 11:33 PM
zay52790's Avatar
its the same like a sub, i don know what the guy at the store was talking about
Old Oct 4, 2007 | 11:35 PM
Joewit's Avatar
Originally Posted by Switt23
Just like a sub.
| [0][0] [0][0] | [0][0] [0][0] |
| (A) | (B) |
|____________|____________|
cool, thanks. i already ran everything but the speaker wires rca's and power are done and the amps not even here yet
anyone know what size capacitor i should go with, i got the 400 4 amp going in and a jl 500/1 for the subs and my lights already dim with just the one amp hooked up.
Old Oct 7, 2007 | 11:21 PM
Joewit's Avatar
10101010
The Rookie24
Jan 20, 2016 05:14 PM
chefhhr
Oct 26, 2015 10:36 PM
c_m_shooter
Sep 27, 2015 04:40 PM
Turbo6
Aug 27, 2015 08:37 PM
forge
Nov 11, 2005 02:44 PM
