need help installing subs and amp
Old Nov 9, 2006 | 07:15 PM
mikess06's Avatar
ok here i go i'm keeping the stock HU and i'm adding subs and amp all i need to know is 2 things where should i hook up the remote wire? and i bought the converter hi low thingy but i can't tell which is the + and - of the rear speakers anyone help me out??? i have a ss sc thanks..
Old Nov 9, 2006 | 08:14 PM
mikess06's Avatar
ok i figure i'll try to run the remote wire to that wire in the pass kicker panel
now i just need to know how to tell the + and - of the rear speakers??
Old Nov 9, 2006 | 08:15 PM
JRANGER's Avatar
Run it from the Red/Power wire of the cd player...This way when you turn the unit on the amp will turn on. Im not sure if it red but do a search for a thread called pin out
Old Nov 9, 2006 | 08:18 PM
Red06LS's Avatar
Ok i did what you are trying to do and then i changed my sub and amp and after the switch it didnt work (fucken pissed) so im just getting a new deck. I know its not any help to you but its not worth all that crap/ taping into speakers and suff IMO. I know it will work good if you can get it all hooked up right and **** but its just not as easy as getting a new deck.
Old Nov 9, 2006 | 08:21 PM
mikess06's Avatar
i got everything else hooked up i just needed to figure whats the + and - on the rear speakers both i believe have black lines on them
Old Nov 9, 2006 | 08:23 PM
JRANGER's Avatar
The darker wire will be the ground....
Old Nov 9, 2006 | 10:48 PM
mesatrin's Avatar
Originally Posted by my self
I just used my DMM and tested the wires in the back of my car.
Back L
black (+)
yellow (-)
Back R
Dark Blue (-)
Light Blue (+)
This is from an 06 ls though
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
Bohb
Sep 27, 2015 09:11 PM
c_m_shooter
Sep 27, 2015 04:40 PM
