New amp with whine?
Old Jun 14, 2009 | 04:40 AM
brickloaf's Avatar
my amp made a loud whine noise right before it blew out a bunch of mosfets and blew my fuse up like a bomb
Old Jun 14, 2009 | 02:27 PM
ctcsoccer7's Avatar
Originally Posted by Homestar1217
this is just what he told me. He told me that because my HU is stock, the factory harness is still there, and that's the only thing he can think of that's causing the whine. I know I don't have a clue, but I do know that I can't have the gains up as high as they should be cause the stupid whine gets worse when you do that.
OK what bestbuy does this guy work at? because saying the harness has something to do with the whine is like saying your floor mats cause engine noise! I work at BB and that is the dumbest thing ive ever heard (BESIDES CHECK YOUR BLINKER FLUID). I had whine and i took out my seats and ran everything down the center of my car away from all electrical wire, did a return ground, and made the amp ground alittle shorter and worked like a champ, i eventually took out the amp but that was for money issues! Whats this i keep hearing about grounding the RCAS on pioneer decks?
Old Jun 14, 2009 | 02:30 PM
Homestar1217's Avatar
He put 2 new LOCs on it a while back to fix an issue with the door speakers, and the noise persists. I don't think they're grounded. The power wire goes to the battery in the trunk, i don't know about the ground I'll look and post after I get home from work. There are 2 LOCs, I have one for each amp.
Old Jun 16, 2009 | 10:35 AM
EmperorJJ1's Avatar
google pioneer pico fuse
http://www.icixsound.com/vb/showthre...7&page=1&pp=10
Old Jun 16, 2009 | 02:13 PM
ctcsoccer7's Avatar
got it!
Old Jun 16, 2009 | 02:28 PM
the power wires on both amps run to the battery down different sides of the trunk, and the ground wires for both amps are just grounded to the metal right under them.
Old Jun 16, 2009 | 04:14 PM
EmperorJJ1's Avatar
Run a ground straight to the battery. and it shouldnt matter how the power wires are ran as long as they dont cross the rcas. In the case of the cobalt the RCAs should only be wired in the front and power in the back
Old Jun 17, 2009 | 12:38 AM
do i take the one off the metal part of the trunk and run it to the negative on the battery?
Old Jun 17, 2009 | 03:36 AM
EmperorJJ1's Avatar
yes.
Old Jun 18, 2009 | 12:39 AM
i'm gettin best buy to do it tomorrow, i don't feel like finding a wire that's long enough. the guy grounded it with the same screw the other amp is grounded with.
Old Jun 18, 2009 | 07:12 AM
  #36
dunit121's Avatar
lmao that explains whine.
Old Jun 19, 2009 | 04:32 AM
  #37
ok. problem is somewhat solved. guy at best buy said he wouldn't run it to the battery because you were never supposed to do that, the wire was supposed to be as short as possible. he regrounded it somehow, i haven't looked yet, and then turned down the amp and loc gains. so the whine is gone. and even cooler my blinkers are actually normal volume now, which I am thoroughly enjoying . So far the only con is that, once again, the gains have to be down, which means a lot less volume with every click of the knob, and i had to change the speed sensitive setting again. So we'll see if I can live with this. I like the HU that's in the car, plus when people look in they can't tell I have a system since it looks totally stock, but if a new HU that doesn't need LOCs will fix the problem, plus the harness thing, I might have to bump that on the list of upgrades for the future. Thanks for the help guys.
Old Jun 19, 2009 | 04:43 AM
  #38
EmperorJJ1's Avatar
the harness isnt an issue turning down the gain is just a band aid on the issue u need to get that ground loop taken care of
Old Jun 19, 2009 | 04:50 AM
  #39
well i don't trust myself to do anything with the electrical on that stuff, I know too little. I'm learning, but I'm still not quite comfortable with that. If it needs to be run to the battery, I might be able to get my friend who got creds to do it for me, but why would he say it shouldn't ever be run to the negative and you say it should? I trust you Emp cause you've helped me before, just curious.
Old Jun 19, 2009 | 05:11 AM
  #40
EmperorJJ1's Avatar
because in 98% of cars the battery is up front. running a ground to the battery isn't efficient and ends up being worse then a body ground. in cobalts where the battery is right there is more efficient and has less resistance to run it straight to the batt
ill be honest the ground shouldn't give your system the alt whine BUT it can. considering he supposedly tried everything else it cant hurt. alt whine is really hard to figure out because there's alot of factors that could be a possibility but i think your installer is looking at the issue incorrectly
Old Jun 19, 2009 | 04:34 PM
  #41
Spun's Avatar
It looks funny seeing that in your trunk now
Old Jun 20, 2009 | 01:37 AM
  #42
EmperorJJ1's Avatar
i know all my pics are old and ****. i need to get some updated ones
Old Jun 20, 2009 | 04:06 AM
  #43
my battery is nowhere near that close to my amp, I mean it's not far... I'll try to get a picture of the trunk up if I can soon, and you can tell me what you think. It would involve a considerably longer wire to ground it to the battery.
The Rookie24
Jan 20, 2016 05:14 PM
chefhhr
Oct 26, 2015 10:36 PM
c_m_shooter
Sep 27, 2015 04:40 PM
ashalle2
Sep 16, 2015 10:36 PM
slowbalt21
Aug 30, 2015 05:54 PM
