New here, audio problems!
Old Apr 9, 2008 | 04:31 PM
McKeough's Avatar
Hey guys!
I'm far from a car junkie, so please excuse my ignorance!
Anyway, I have a 2005 Cobalt Coupe, and love it. Will be upgrading to a new SS when I have the funds, just isn't in the budget ATM.
Anyway, never had any problems with the car, perform regular maintenance on it, etc.
However, the other day my driver side door speaker stopped working. I don't think it's blown or anything, because it worked when I parked the thing in my garage the day before! It wasn't distorted or anything leading up to the malfunction, either.
I'm wondering is it possible that a wire popped off or something?
Ah, as I said, I'm pretty clueless when it comes to this. Anyway encounter any similar problems, or is this a problem that maybe occurs frequently?
Just wondering if anyone has any suggestions!
Thanks for the help,
Kayle.
Old Apr 9, 2008 | 04:33 PM
skymynx's Avatar
its highly unlikey the wire popped off but possible i suppose. the speaker is most likely blown and you just didnt notice it before
Old Apr 9, 2008 | 04:36 PM
McKeough's Avatar
Hmm, is this a pricey fix? I'm sure taking to GM to have fixed would cost quite a pretty penny.
It definitely wasn't blown the night before though, I'm sure of that. I know for a fact there was sound coming from it!
Thanks for the prompt response, though.
Old Apr 9, 2008 | 04:38 PM
mikejoness61's Avatar
check fuses?
Old Apr 9, 2008 | 04:40 PM
McKeough's Avatar
Originally Posted by mikejoness61
check fuses?
I'll... get right on that?
*cough* How does one go about doing that?
Old Apr 9, 2008 | 04:43 PM
umm not sure which fuse box they are in... one fuse box is under the hood and the other is lets say your sitting in front passenger seat it would be at your left foot behind that panel and you have to pull that panel off but check the drivers manuel to see which fuse box they may be in
Old Apr 9, 2008 | 04:47 PM
calchr2's Avatar
do oyu have the factory sound system components or are they aftermarket? if factory and your car is still under warrenty, i would take it to the dealer and have them look at so you dont have too.
Old Apr 9, 2008 | 04:49 PM
McKeough's Avatar
What would I be looking for in the fuse box, though?
It's factory, but it's not under warranty anymore, and, as I said, I'm sure they'd overcharge quite a bit if I took to the dealer.
Thanks guys!
Old Apr 9, 2008 | 04:51 PM
yeah def just do that if its stock why waste your own time trying to figure it out
one suggestion make some friends at a dealership
but look for the i dont know AUDIO speakers or something realating to the speakers fuse on one of the diagrams on the fuse boxes and check the fuse
Last edited by mikejoness61; Apr 9, 2008 at 04:51 PM. Reason: Automerged Doublepost
McKeough's Avatar
Not under warranty, though.
I guess I can call and see what I'd be looking at cost wise, but if it's a simple fix, I'd like to do it myself and save some cash!
Old Apr 9, 2008 | 04:56 PM
rnjmur's Avatar
There are 3 possibilities here:
1. The speaker is blown. You will need to take the door cover off to get into the speaker then you will need another speaker to hook into the wires and see if you hear sound out of the new speaker.
2. There is a break in the wire between the headunit and the speaker. If this is the case it can be a pain in the as2 to find, however this scenario would be quite unlikely.
3. The front left channel on the head unit is blown. This will mean replacing the radio.
1 or 3 are more then likely the culprit. Each speaker does not have its own fuse, the radio is run off one fuse. If the radio still works the fuse isn't blown.
Old Apr 9, 2008 | 05:01 PM
McKeough's Avatar
Hey, thanks for the info.
Regarding 3, my radio still works, and all my other speakers do. CD's play fine, as well.
Does this confirm that is isn't blown?
Old Apr 9, 2008 | 05:11 PM
rnjmur's Avatar
You CAN have just one channel blow on the radio. I am not sure if the radio in the cobalt has 4 channels or just 2 channels. The speakers are the easiest thing to check. Another thing you can do if you don't have a spare speaker is take the speaker out of the door and hook it up to a home stereo and see if it has sound there. If you get sound when the speaker is hooked up to your home system then the chances are that the car radio is probably going to have to be replaced.
Old Apr 10, 2008 | 05:00 AM
EmperorJJ1's Avatar
how much of the car are you willing to take apart to find the problem?
You can take off the door panel, pull the speaker out, throw a short run of wire to the speaker and attach it to a 9v batt... if it *pops* the speaker works (depending on if you hook it up will determine if it moves in or out but it doesnt really matter) and using a multimeter test if you have AC voltage running thru your stock speaker wires
Or you can Pull your stock HU get some thin wires and put them in the connector where that speaker is hooked up and attempt to pop the speaker that way (use extreme caution if you try doing this because if you dont use the correct wires you can mess up something)
Or you can be lazy and take it to a stereo shop say my stock door speaker stopped working and i want to swap them with some aftermarket ones... find some decent $50 speakers and they will have to figure it out
turbochargedss2012
Sep 20, 2023 12:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
Iceberg
Sep 28, 2015 01:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
