ohms are confusing
Old May 31, 2008 | 03:04 PM
cobaltguy88's Avatar
man go with MTX ftw!! thats my favorite company.. they make solid amps and subs.. thats just me though
Old May 31, 2008 | 08:02 PM
warrenb213's Avatar
the PA stuff is decent if ya don't push em.
I'd like to hear the PA ****....
Old Jun 1, 2008 | 06:22 AM
EmperorJJ1's Avatar
Originally Posted by fmxr47
whatchu lol'n bout, me being indecisive?
no this whole thread in general. hey what was ur old amp?
Old Jun 1, 2008 | 06:01 PM
fmxr47's Avatar
a shitty legacy 1000 watt, rms was 450 @ 2ohm
ok, so i didnt blow my amp, my fuse block melted and the fuse didnt pop, so i think my audio stor gave me the wrong fuse for my amp and everything, but i put in another amp and subs i had and it still doesnt work, could i have fried something else?, i am using a line out converter if that matters at all?, i like the stock headunit untill i get my dbl din touchscreen
Old Jun 2, 2008 | 01:53 AM
EmperorJJ1's Avatar
test for 12v using the pos and ground on the amp, test for 12v using remote and ground on the amp and test for ac voltage on the RCA and at the amp outputs... could easily be the fuse on the remote wire
Old Jun 2, 2008 | 02:08 AM
fmxr47's Avatar
checked the fuse on the amp and on the remote wire, they are fine, im hoping its just i need a new fuse block, i noticed that the stock sub is crackling now, so i think i may have fried something, but the stock sub was not touched at all by me, could i have fried my line out converter?
Old Jun 2, 2008 | 10:01 AM
EmperorJJ1's Avatar
wait the fuse on ur power wire still hasnt been replaced?
Old Jun 2, 2008 | 12:09 PM
drewski's Avatar
you wouldn't have fried your line out converter, there is no component to fry on it. more than likely if your fuse was too big, you sent a surge through your amp and this is where the problem is. what damage it has done, i can't say. and your stock sub isn't/shouldn't be hooked up to your line out converter, so that wouldn't cause crackling in the first place.
recheck all your connections and do a 12V test there as well as Emperor said. most of the time, crackling is cause by faulty hookups. also make sure you do not have power cables running next to signal cables, these should be run down opposite sides of your car.
Old Jun 2, 2008 | 05:30 PM
fmxr47's Avatar
k, im getting a new fuse block tomorrow, cause mine melted into a pudle of plastic, im lucky there wasnt a fire. and im checking and rechecking all of the connections
Meadowvalien
Aug 17, 2017 06:32 PM
ashalle2
Sep 17, 2015 04:58 PM
TheDriver!
Nov 5, 2005 07:48 AM
Taro
Aug 10, 2005 01:08 AM
