Parking brake switch
Old Feb 27, 2009 | 08:21 AM
Rydis's Avatar
Anyone know where this is located? Want to finish hooking up my avic f700bt and this is the only wire I can't figure out. I checked the carpt and took off panels near the parking brake but there is no green wire here. Just a black one...so im confused on where it is or where I should look for it.
Old Feb 27, 2009 | 02:02 PM
stinkyfisherman's Avatar
What year is your car? Its the only wire that attaches to your parking break. On my car its a light blue wire at the parking break but I have a 05'. Why dont you just bypass the f700?
Old Feb 27, 2009 | 03:48 PM
Rydis's Avatar
Oh ok, mines black then. Its an 06 ss/sc. I read its suppose to be green, but maybe mine was changed before I bought it then, so I just wanted to make sure.
I tried, but you can't access any of the system settings unless its hooked to the parking brake, so I can't bypass it without getting into the system settings.
Old Feb 27, 2009 | 04:10 PM
ok i know how to bypass it.
on your RCA harness you have the mute wire (yellow/black) its on the last pin out on the harness.
pull it out and move it down one and over 4 spots to the open spot inbetween the two black wires that turn into the rca's. glue it in (I use super glue jsut a small dab).
then ground out the mute wire (yellow/black) ground (black) and parking break (light green)
DONE that will bypass it just fine. I'll post a pic for you when im off work
Old Feb 27, 2009 | 05:04 PM
Rydis's Avatar
alright thanks!
Old Feb 27, 2009 | 10:20 PM
EmperorJJ1's Avatar
does that work for the new F series hus? i thought it was only for the older 04-07 stuff
Old Feb 27, 2009 | 10:25 PM
its a diffent pin out now. I need to post my picks so I'll show you soon.
Old Feb 27, 2009 | 10:34 PM
dman090's Avatar
i need to find a new as the ground it to a switch isnt working
Old Feb 27, 2009 | 10:38 PM
EmperorJJ1's Avatar
huh any wires came loose?
Old Feb 27, 2009 | 10:50 PM
Ok here it is...
The top pic with the red circle is the original pin out of the mute wire (yellow/black)
the bottom pic with the red circle is where it needs to end up.
Old Feb 27, 2009 | 11:12 PM
dman090's Avatar
wel it nvr did work 100% from the start
and now it wont work at all, mabe i have a bad ground idk?
Old Feb 27, 2009 | 11:58 PM
EmperorJJ1's Avatar
hmm when you say not work 100% what do you mean? you should have had long enough wires on the switch to wire it directly with the radio/harness ground
Old Feb 28, 2009 | 12:03 AM
dman090's Avatar
well i didnt ground it there lolm i grounded it under the ebrake, smae place ebrake is grounded at
Old Feb 28, 2009 | 03:44 AM
EmperorJJ1's Avatar
hmm... no idea how good of a ground that is
Old Feb 28, 2009 | 03:15 PM
Rydis's Avatar
Ok here it is...
Thanks, got it all working
Old Mar 1, 2009 | 12:08 AM
Sweet!
06MetallicBalt
Jul 20, 2025 08:47 PM
Jan 12, 2016 12:01 AM
biniecki
Oct 25, 2015 02:23 PM
