Passanger side projector wont light up
Old Oct 12, 2011 | 02:14 PM
brickloaf's Avatar
Just made a thread about the halos on my brand new gen 1's, the driver side works perfect, and the passanger side also works perfect (turn signals, high beams, etc) but the projector will not turn on, everything is attached correctly and i tried to use a ballast from my old HID kit with no luck.
anyone got any ideas??
thanks
Old Oct 12, 2011 | 02:20 PM
royce777's Avatar
bulbs prob bad. try fuse first tho
Old Oct 12, 2011 | 02:26 PM
brickloaf's Avatar
wouldnt the highbeam not work either? ill check the fuse though
Old Oct 12, 2011 | 02:29 PM
padlock's Avatar
well your options kinda lie in either a bad bulb, ballast, fuse or ground(if you have a relay).. so test it and see what it could be by trial by error..
Old Oct 12, 2011 | 02:39 PM
brickloaf's Avatar
well it was a plug-n-play set up so i dont believe there is a relay, and i already tried another ballast that works perfect. like i said ill check the fuse but my passanger side HID worked fine before i installed this one. so I guess it might be a bad bulb
Old Oct 12, 2011 | 03:07 PM
brickloaf's Avatar
welp just switched the headlight fuse and no luck....guess its a bad bulb. i would have thought that the vendor would have tested them before shipping out..
Old Oct 12, 2011 | 03:10 PM
eccarwiz's Avatar
I had this same problem. Got a set of retrofit lights and the drivers side worked perfect but the passanegr side would only work in high beam mode. turned out that the wiring harness was pinned incorrectly so i had it repinned
Old Oct 12, 2011 | 03:12 PM
brickloaf's Avatar
the hid bulb is only connected to the ballast though? through the 2 circle shaped input/outputs
retrofits are different though, high beam and low beam come from the same bulb i believe
Old Oct 13, 2011 | 10:41 AM
EmperorJJ1's Avatar
ya sounds like a bulb issue. id also double check it by plugging it in the drivers side just in case its wiring.
Old Oct 13, 2011 | 11:17 AM
keiserX13's Avatar
switch the bulbs & ballast
whichever the problem stayed with is the bad one
where did you get the HIDs from?
Old Oct 16, 2011 | 05:49 PM
brickloaf's Avatar
welp it is not the bulb, i did what empjj recommended and took out both headlights and hooked up the driver side light (working) to the passenger side wiring and the bulb wouldnt light up. like i said i have tried another ballast so it has to be the wiring.
does this sound like an issue with the 9007 plug? im pretty sure thats the only thing that affects the low/high beam.
Old Oct 16, 2011 | 05:53 PM
brickloaf's Avatar
also i got em from buyhids.com
Old Oct 16, 2011 | 06:02 PM
TommyP's Avatar
AWD > FWD
well if you're sure it's not a blown fuse, ballast or bulb, start tracing wires, check each connection and looks for burns/melting. Somewhere along the line there has to be something disconnected, broken, or melted.
Old Oct 16, 2011 | 06:19 PM
brickloaf's Avatar
will do, but my old HID's worked perfectly fine so im assuming is has to be a problem with a wire/connector that came connected to the HID....so i dont have to many wires to check...
Old Oct 17, 2011 | 12:07 AM
EmperorJJ1's Avatar
very possible they corrode and rust alot
Old Oct 17, 2011 | 11:21 AM
brickloaf's Avatar
true but the projectors were brand spankin new so they should be all good...im thinking its the 9007 harness/connector thats causing problems so i am going to take the old 9007 harness from my last HID's and splice the wires and use the old 9007 harness on the new projector....
well seee
Old Oct 17, 2011 | 01:47 PM
EmperorJJ1's Avatar
thats what i meant the 9007 plug
Old Oct 17, 2011 | 02:08 PM
brickloaf's Avatar
well just spliced in the 9007 from my old HID bulb and its still the exact same thing....that leaves me only 2 options, the 2 wires (red/black) that come straight off the bulb (connections to the bulb are secure) with the input/output plugs, and the rectangle shaped plug that is also connected to the bulb.
this is getting retarded...
Old Oct 18, 2011 | 01:02 AM
EmperorJJ1's Avatar
huh... thats crazy
Solaris99
28
Mar 15, 2017 01:22 PM
biniecki
Oct 25, 2015 02:23 PM
dennis69
Oct 20, 2015 04:49 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Tupp
Sep 30, 2015 08:18 PM
