Pioneer speakers impedence
Old Mar 3, 2008 | 07:14 PM
kingarthur's Avatar
Would anyone know if the Pioneer speakers are 2 Ohm or 4 Ohm.
Just about to change the HU and will be using the pioneer speakers until I can purchase other speakers.
Old Mar 4, 2008 | 02:29 AM
SS SCHGD's Avatar
I think there 2ohm, be careful
Old Mar 4, 2008 | 03:16 AM
EmperorJJ1's Avatar
yes they are 2 ohm... use them but dont go crazy with the volume and u will be fine as long as you get new speakers sooner rather then later
Old Mar 4, 2008 | 06:20 AM
kingarthur's Avatar
Would it be safer to put the base speakers back in?
Old Mar 4, 2008 | 06:37 AM
skymynx's Avatar
what speakers are in there right now stock ones?
Old Mar 4, 2008 | 08:11 AM
kingarthur's Avatar
Right now I have the stock Pioneer in the car.
I previously had the base audio system that comes standard with the LS.
Old Mar 4, 2008 | 08:14 AM
skymynx's Avatar
oh ok. if your that worried about it, put speaker savers in
Old Mar 4, 2008 | 09:04 AM
kingarthur's Avatar
speaker savers?
Never heard of those.
Old Mar 5, 2008 | 06:06 AM
EmperorJJ1's Avatar
safer? ya
wait did u ever get the stock amp workin?
speaker savers?
i belive he may be talking about bass blockers.... they are basiclly crossovers to take out the bass on midranges (which is what normally "blows" them in the first place) but since ur issue is a low ohm load they wont help u
Old Mar 5, 2008 | 06:18 AM
kingarthur's Avatar
Stock amp is working but decided to get a new HU with more options
Old Mar 5, 2008 | 06:35 AM
EmperorJJ1's Avatar
if you have the stock amp then it wont matter... but i would pull it once u get aftermarket speakers.
Right now adding the aftermaket hu will give u a bunch of overlap power wise (not good but not really bad either) because you are giving the amp an already amped signal to amplify. But once u get aftermarket 4 ohm speakers then you are getting only half of the signal the stock amp is supposed to put out. so the stock amp ends up just being a noise maker.
Jan 12, 2016 12:01 AM
chefhhr
Oct 26, 2015 10:36 PM
nathan112i
Sep 30, 2015 07:12 PM
Sep 27, 2015 08:53 PM
