possible to fit a different 10" in factory pioneer box?
just wondering if anyones knows if it is possible to fit a different 10 inch sub in the factory 10 inch pioneer box? or should i not even bother and just build a lil box myself... thanks guys.
I was wondering the same thing.. Also I was wondering if they made a box for the other side to match .
the thing is i dont want to add alot of weight to the car...
I saw a how to on this.. let me try to find it.
https://www.cobaltss.net/forums/how-guide-43/how-upgrade-rear-sub-78178/
I think that is what you're talking about
Last edited by sean_halla; 11-10-2008 at 11:26 PM. Reason: found a post that i think is right
yea thats what i was talking about. thanks dude. i think i will end up making a box. might take out the spare tire and build a box to fit. if i get a flat, thats what AAA is for. haha.
yea id say dont bother...you need a certain air space for each sub and once u upgrade to somthing nicer, that box just isn't going to cut it. its pretty cheap now to get just one 12 in. sub and a box with a small amp. possibly 500 with install altogether unless you know what you're doing with audio, in which you'd install it yourself.
for those wanting to know about replacing the factory sub in the pioneer box,I have changed my factory sub with an Alpine sub,shallow type, in the factory box,same type 2 ohm.It does in fact sound better but upgrading to an amp and sub in another box I'm sure would sound better.The Alpine sub that I put in does fit just that the pioneer grille will not work on the new sub and I added some extra padding around the bottom seat of the sub where it mounts to the box.The Alpine does sound much cleaner over the factory sub but for now it will do.For whomever is wishing to do the same,I have the Alpine sub model number if your interested,just let me know.
making a wood enclosure in there isn't going to be fun or easy especially if you need a bit of airspace (there's probably only 1 or so cubes of space down there... especially with the battery still in the stock location) it looks big but its really not
true, i am going to car stereo warehouse, its a place close to me, and they build custom boxes, i have been thinking about geting a shallow mount MTX, the new ones, or maybe one of the new memphis S class shallow mounts. i gotta get a 12. 10 in a seald box wont cut it for me. if i get a shallow mount i shold be good, and yea it looks big untill you measure it out.
EQ your input signal to tune out the droning bass frequencies and your sub will hit REALLY hard. I love how mine sounds, it sounds aftermarket and rattles my door skin
very interested in making my sub sound better,not sure what you did to yours as i still have the factory radio,and 7 speaker pioneer set-up.will what you did work on my system?thanks
yeah i changed the sub,put in an alpine sounds much better but needs more umph.Would it be possible for you to forward the amp you purchased and how you wired it in,hopefully is easy.thanks
i want to do a full system now, there is only so much you can get out of that factory box...
i went to a local shop. they are kinda expencive, but warrenty their work for the full time i have the car. i talked to the guy i have talked to and baught from before, got a few quotes with different subs and different amps. mainly going with JL, and one setup has an alpine amp. and they warrenty the subs and amps for a minimum of a year, or 2 years. he told me right then and there that i can go somewhere and get it for cheaper but they wont warrenty it at all. if i blow out a sub compleatly, i take it there, they put in a new one, FOR FREE.
these are the quotes...
1-
JL 12 inch w3
JL amp
ported box
labor
wire
=$716
or w/ JL w1
=$600
2-
2 JL 10inch w3
Alpine 1000 watt D class amp
ported box
labor
wire
=$1200
or w/ JL w1
=$820
SS SCHGD-
does it sound good? nice and deap, and does it hit hard?
1-
JL 12 inch w3
JL amp
ported box
labor
wire
=$716
or w/ JL w1
=$600
2-
2 JL 10inch w3
ported box
labor
wire
=$1200
or w/ JL w1
=$820
SS SCHGD-
1-
JL 12 inch w3
JL amp
ported box
labor
wire
=$716
or w/ JL w1
=$600
2-
2 JL 10inch w3
ported box
labor
wire
=$1200
or w/ JL w1
=$820
SS SCHGD-
1-
JL 12 inch w3
JL amp
ported box
labor
wire
=$716
or w/ JL w1
=$600
2-
2 JL 10inch w3
ported box
labor
wire
=$1200
or w/ JL w1
=$820
SS SCHGD-
It is not 2000 watts RMS in to 2 12's (like my other car was) But I am very happy with it.
