Power Tap
Old Apr 2, 2009 | 05:01 AM
HunterKiller89's Avatar
Power Tap
Anyone know of any quick 30amp places to tap for power?
Old Apr 2, 2009 | 10:33 AM
brickloaf's Avatar
fuses under the dash
Old Apr 2, 2009 | 02:15 PM
u mean the passenger side fuse panel? None of those are 30A, theyre all 10A or 15A, with a couple 20A. The only 30A is a funky 4 prong fuse for the power windows (that i dont have, so no fuse there either)
Old Apr 2, 2009 | 08:37 PM
sptrdss's Avatar
I purchased these for my 09 balt,need them for my amp and work really great!
http://www.accessafuse.com/
Hope this helps,good luck.
Old Apr 4, 2009 | 02:44 AM
EmperorJJ1's Avatar
nice concept... not really what hes looking for thou.... im pretty sure there isnt one on the interior fuse panel and no idea on the one in the hood
Old Apr 4, 2009 | 04:30 PM
i think im set. I found something akin to this:
http://www.scootonthis.com/images/jp...E/Conn3389.jpg
only instead of a socket connection, it has 2 prongs on it, and it happens to be the exact same size as our fuses, so I can swap a fuse with one, and have a tap. The only downside is whatever i swap it with will no longer be fused, so ill just swap it with something that wouldnt ever see too much voltage/amperage, or something thats easily replaced if it ever DOES see too much
Old Apr 4, 2009 | 08:56 PM
EmperorJJ1's Avatar
the only issue with that is how much current your gonna draw thru that wire... if you hook up everything to one power source that wire will melt. you can add a little here and a little there but tread softly
Old Apr 4, 2009 | 08:58 PM
BLAZIN07SS's Avatar
I'm too JDM for you
what are you putting in that draws that much amperage?
Old Apr 4, 2009 | 09:05 PM
EmperorJJ1's Avatar
power windows if i remember correctly... those motors are beasts (**** mine dim the lights stock)
Old Apr 4, 2009 | 09:29 PM
yea, power windows. I just finished the install today. the stock power window fuse is a 30A fuse, so yea, they suck up quite a bit of power. Anyway, it looks factory, i used factory motors, SS door panels, SS bezels (the driver side bezel has aftermarket buttons, but they fit pretty well), its in a switched source (key has to be ON, not accessory tho), and everything is done pretty well. soldered all joints and heat shrink around each one afterwards. I'm happy now
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
ernnyyes
Oct 2, 2015 05:16 PM
Stuff
Oct 1, 2015 05:47 PM
goaliemo
Sep 28, 2015 01:37 PM
