question about stock head unit
Old Dec 12, 2006 | 07:40 PM
mjesenovec's Avatar
does the stock head unit on an 06 ss/sc have RCA input jacks in the back?
Old Dec 12, 2006 | 09:10 PM
cobalt25's Avatar
I have not looked but I am willing to bet money that they don't 99.9999999% sure. Have you seen a factory radio that did?
Old Dec 12, 2006 | 09:11 PM
Xavipheus's Avatar
No it dosent
Old Dec 12, 2006 | 09:25 PM
Brraaapp's Avatar
If you are looking to put a stereo system in your car with the stock radio you can use a high low converter you can find a decent one for about 30 bucks. since you dont have a power antenna, and since its a bitch to tap in to your wiring if you dont know what your doin then just use a fuse that will shut your amp off when the key is in the off position otherwise your battery will be die(remote wire). also make sure its atleast 10amp fuse to be on the safe side.
Old Dec 12, 2006 | 09:46 PM
cobalt25's Avatar
If you are going to put a hi low converter in than you have to go off of your rear speakers or better yet your stock sub. So you mite as well just put a low voltage trigger in you won't
have to wire in to your fuse box.
But first check your amp and see if it has high level inputs if so more than likeily you won't
need a switch wire at all or a hi low converter this is the best way that i know of
Old Dec 12, 2006 | 09:48 PM
Brraaapp's Avatar
OR do what he said!
i just did it the other way and i did tap into my rear speakers
Old Dec 13, 2006 | 12:00 AM
mjesenovec's Avatar
ok...i already have my kenwood amp and 2 kicker 12's set up...my friend tapped into the 6x9's for the signal. I wanted to know because i found an aux jack that plugs into rca jacks....so i can plug my mp3 player into my stock head unit...but since it doesn't have rca jacks...then the idea is done.
Old Dec 13, 2006 | 12:07 AM
kingg5's Avatar
I have not looked but I am willing to bet money that they don't Have you seen a factory radio that did?
yup have u ever seen a ford explorer sport trac adrenaline...it has a double din pioneer deck FACTORY. and it has preouts.
could be a kenwood...cant really remember..but its a double din..and i know it has preouts
Old Dec 13, 2006 | 12:10 AM
kingg5's Avatar
just wondering...does ur deck have that little hole in the front to hook up a mp3 player with a headphone style cord or whatever...if it does..couldnt u get a cord that is ...on one end a headphone plug..or mini plug i think they may be called...and at the other end two rca's?
Old Dec 13, 2006 | 12:19 AM
207GT04's Avatar
there has to be a better way to get subs in there without splicing wires and messing around with the stock audio. i mean pac audio made a stock audio intergration for my grand am GT with monsoon that just was a device that pluged into the stock place in the back of the deck and the regular monsoon plugged into the device. and outta the device came a set of rca jacks for subs or more speakers or whatever. email pac audio about this a couple days ago and still no response. hopefully they will have something like that for us in the future so we dont have to be cutting wires
Old Dec 13, 2006 | 12:32 AM
mjesenovec's Avatar
no...it doesn't have the aux jack or the little "hole"...and that's what i want. I think you misunderstood what i was asking....i dont need to plug anything into rca jacks....i wanted to know if the back of the head unit had rca jacks as outputs so i could plug in an adapter...but it looks like i'll have to go the route of wired fm transmitter.
Old Dec 13, 2006 | 12:35 AM
cobalt25's Avatar
I learn something new everyday
Old Dec 13, 2006 | 12:40 AM
kingg5's Avatar
oh my bad man sorry about that.
kingg5's Avatar
glad to help at least i got one thing right this thread lol
Old Dec 13, 2006 | 12:41 AM
cobalt25's Avatar
there is if you have the money jl audio has a i can't think of yhe name of it but it just came out last year .
It goes behind the deck you plug all your speaker wires in one side and it gives you 2 or 3 rca outputs if you already have the pioneer system i think you will have to replace your stock amps = stock speakers too
Old Dec 13, 2006 | 10:18 AM
Brraaapp's Avatar
good luck man!
ineedacobaltss
Nov 7, 2015 02:25 PM
brandon04
Oct 21, 2015 07:04 AM
nathan112i
Sep 30, 2015 07:12 PM
Sep 27, 2015 08:53 PM
