Question about sub preout wiring
Old Nov 5, 2006 | 10:38 PM
Xavipheus's Avatar
Real quick guys, whats the best wire setup for my sub pre-outs? Should i get 2 rca lines? Or one rca line for white to white? Or should i get one like computer cable and get a Y adapter for each end? Suggestions please, Im doing this tomorrow
Old Nov 6, 2006 | 08:24 AM
mesatrin's Avatar
Use a normal double RCA cable that you would get for any car audio. If it is an actual sub pre-amp out then it will already be mono. If your using a monobock then the amp normally monos the signal for you. The only way you could really have a problem is if you are running one channle to each voice coil...other wise even if the signal is not mono it doesn't matter.
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 07:39 AM
ernnyyes
Oct 2, 2015 05:16 PM
jmelton327
Sep 26, 2015 10:04 PM
