quick amp question
Old Nov 22, 2006 | 09:54 AM
xspyder85x's Avatar
quick amp question
if the amp im using says 200 x 2 @ 2 ohm. and i make the subs run at 1 ohm, will the amp be ok to run at 1 ohm? i know a lot of amps will double the power at 1 ohm, but this spec sheet doesnt metion anything about 1 ohm. where as other amps will run 1 ohm. i jsut want to know if it will give me the one ohm level or will it run at 2 ohm and kill my amp over time. thanks.
http://www.crutchfield.com/S-bgshDPY...arch=kx400%2E2
Old Nov 22, 2006 | 09:57 AM
xspyder85x's Avatar
i think i found it, i may throw a short circuit protection switch. this is done by the speakers operating under the minimum impedence (ohms). so i put it up here in case anyone esle wants to know.
Old Nov 22, 2006 | 10:26 AM
Bandit2941's Avatar
Yeah....
If the amp doesn't explicitly say it's 1 ohm stable, it's highly unlikely that it is.
Old Nov 22, 2006 | 10:28 AM
xspyder85x's Avatar
ok thanks for the conformation.
Old Nov 23, 2006 | 04:08 PM
SilverTurboRidin's Avatar
Yeah i know for a fact that amp isnt 1 ohm stable...lol...
Old Nov 25, 2006 | 07:24 AM
EmperorJJ1's Avatar
if you run an amp under its "stable" ohm level then theres a good chance you could mess it up unless its been modded to accpet that ohm level. even then its very risky and for a daily driver its not worth it. Oh and btw the power level on diff amps dont exactly double when ohm is dropped but especially when going below rated ohm level dont expect double the power. IMHO i would get a 1ohm stable amp if thats the ohm level you want... I would recommend the T3002 amp by rf to you but it maybe more power then your looking at
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 07:39 AM
patooyee
Oct 15, 2015 05:11 PM
Extremespeed
Sep 29, 2015 04:34 AM
c_m_shooter
Sep 27, 2015 04:40 PM
