Radio help
Old Apr 24, 2011 | 04:14 PM
Bluebalt1's Avatar
Radio help
I have an 08 cobalt and I want to put a pioneer h/u in it. I don't have on star or premium radio. I got a fm adapter and wired an ignition source to it and when I tried everything out none of the speakers worked and none of the gauges or chimes worked. I'm fine with the chimes not working. But I not ok wit the tach fuel and speedo not workin did I do something wrong or do I need that $$$$ adapter
Old Apr 24, 2011 | 04:15 PM
Bluebalt1's Avatar
Ps I have been looking and can't find any info on the gauges being affected. Thanks
Old Apr 24, 2011 | 06:46 PM
c4w18's Avatar
check your fuses. what did you wire the ignition to?
Old Apr 24, 2011 | 07:01 PM
RedStil's Avatar
ehmmm hahaha u fcked ur fuse..
Old Apr 24, 2011 | 07:59 PM
cobalt2010's Avatar
^^hes a new guy. get off his ass.
as for the fuse situation. yes its done. which one was it?
Old Apr 24, 2011 | 08:05 PM
Bluebalt1's Avatar
It's not the fuse put the stock one back in and everything works
Old Apr 25, 2011 | 01:09 AM
c4w18's Avatar
stock radio back in you mean?
Old Apr 25, 2011 | 03:16 AM
EmperorJJ1's Avatar
what harness did u use?
the problem is ur ******* with the gm lan wire its hooked up to power or speaker or something so its pissing off the BCM. i would proceed with caution u dont want that bitch to shut er down
Old Apr 25, 2011 | 02:22 PM
c4w18's Avatar
yea hopefully he didn't shoot off a positive to a BCM input or his pickle is going to be tickled.
Old Apr 25, 2011 | 05:48 PM
EmperorJJ1's Avatar
how can the site sensor **** but not bitch?
Old Apr 25, 2011 | 09:48 PM
c4w18's Avatar
well now i see both words....
Old Apr 25, 2011 | 10:05 PM
EmperorJJ1's Avatar
right me too idk thats crazy
Old Apr 25, 2011 | 10:13 PM
c4w18's Avatar
Hey JJ what kind of enclosure you got in your ride? J/w got a couple questions
Old Apr 25, 2011 | 10:22 PM
EmperorJJ1's Avatar
sealed double chambered 2.5cu per sub
Old Apr 25, 2011 | 11:09 PM
c4w18's Avatar
forward firing? i've got 2.5 cuft too but it's ported and I'm thinking the width of the box is ******* with the sound....not enough bass getting into the cabin...how wide is yours?
Old Apr 26, 2011 | 01:03 AM
EmperorJJ1's Avatar
yup forward firing. Thats the main problem with 15s is not enough room to let air back in the cab if it fires back. how tall and wide is your box. try scooting it back towards the trunk and see if that helps.
mine is 16" tall 37 i believe wide on the bottom and like 30 wide on top
i'm surprised you've never seen my box.
Old Apr 26, 2011 | 08:01 PM
c4w18's Avatar
well we essentially have the same dimesions as well as exact same volume, but mine has port/sub facing the rear and I definitely feel like it's not transferring right...loads off the trunk SO hard yet not much gets to the front cabin. I guess I'll try moving it more towards the trunk a little bit or even forward fire it to see the difference...I've always been against forward firing though with a bass reflex enclosure :[
Old Apr 26, 2011 | 08:04 PM
c4w18's Avatar
you still running those RE's and those amps?
Old Apr 26, 2011 | 09:05 PM
EmperorJJ1's Avatar
Yes on the subs no on the amps... i only ran those amps for a weekend. i needed smaller amps then my ppi's so they fit on the back of the seat better for a comp plus it was close to rf HQ and a few guys planned on showing so figured running some rf amps couldn't hurt
if your box is that big then ya your shooting urself in the foot and trapping the bass in the cab. How deep is it? can u make it deeper and trim some off the top or sides? all i can tell you abotu forward firing is until the second i had it "done" it was hard to be "satisfied" to demo it i had to pop the trunk because theres mad cancellation but once i sealed off the trunk that all went away. mind you i went above and beyond sealing it up. its not quite but pretty close to air tight
Old Apr 26, 2011 | 09:30 PM
Bluebalt1's Avatar
Yes I put the stock radio back in the harness I got my buddy at the local stereo shop gave me and said all I needed to do was run a hot wire from a keyed hot to the red wire on the radio that's way I did and that's when everything went crazy
Old Apr 26, 2011 | 10:04 PM
c4w18's Avatar
what wire is your ignition?
and yea I already have some new enclosure designs that i sent out for a while back, was just wondering if my current dimensions were part of the reason for my hinderance. thanks for the tips.
Old Apr 26, 2011 | 10:30 PM
EmperorJJ1's Avatar
well all i can say is its the wrong harness. from what ive seen the gm lan wire is purple in our cars but i wouldn't rely on that.
The Rookie24
Jan 20, 2016 05:14 PM
chefhhr
Oct 26, 2015 10:36 PM
agentirons
Oct 16, 2015 02:11 AM
shawnsseries
Sep 10, 2015 08:29 PM
