Registor (1 kohm) What does this mean
Old Dec 28, 2005 | 01:18 PM
hardtocope's Avatar
i have a old panasonic ghost face reciever.. on the accessory wire it has this registor (1 kohm) thing soldered on to the wire.. what exactly does this mean? why do i even need this on my receiver?
Also my book says registor but i think it's suppose to be a resistor?
Old Dec 28, 2005 | 01:21 PM
pclear9061's Avatar
registor or resistor?
Chevypowered's Avatar
its probably a 1K ohm resistor that is used to only allow that much power through it. I think that correct, if anyone knows better chime in.
Old Dec 28, 2005 | 01:23 PM
hardtocope's Avatar
well my panasonic manual says registor but maybe it's suppose to be resistor?
yeah it should, just a typo.
pclear9061's Avatar
if it is resistor then yes . if not then i have no idea. the resistor should be color coded with three stripes, if i remember correctly it should be brow then black then red and either a silver or a gold stripe depending on the % 5 or 10%
Old Dec 28, 2005 | 01:27 PM
hardtocope's Avatar
the reason i ask is because i think it might be damaged?? is there any way for me to replace it or do i have to buy a new deck
Old Dec 28, 2005 | 01:31 PM
go to an electronics store like radio shack and have them test, i think they can there. You can re solder a new on and just replace it if it is damaged.
Old Dec 28, 2005 | 01:34 PM
pclear9061's Avatar
yes just desolder the resister or however it is connected and then replace with a new one ......... but there had to of been a reason for that to go out ........ could have been a short somewhere in the system or it could have been just a bad part, or a huge spike ........ its hard to say but if you do replace it you are going to want to do a good look at everything to make sure that nothing else looks like it is burned or touching eachother and if you do replace it and it happens again you are going to have to look deep into it and start using some testing equipment to find the culprit
Old Dec 28, 2005 | 01:42 PM
Hutch's Avatar
Canada
This is a typo as stated by Chevypowered.
"ohm" is a unit of measurement for electrical resistance. One ohm is the resistance in a circuit when one volt maintains a current of one amp.
Your resistor actually is telling you that you have one thousand (K) ohms.
The Source (Radio Shack) has a replacement and you will be able to resolder.
Sorry for the lesson but its my nature.
Hutch
Old Dec 28, 2005 | 01:43 PM
hardtocope's Avatar
it looks like a small blue can with a few little numbers on it.. i think it said 1023?? it has one metal clamp on each side clamping the resistor on the wire.. thanks for your help guys
Old Dec 28, 2005 | 02:04 PM
pclear9061's Avatar
the blue can is a capasitor not a resistor unless you have a funky ass resistor that i havent seen ......
Old Dec 28, 2005 | 02:06 PM
pclear9061's Avatar
can you take a pic .......... for me its easiser to have a pic to diagnose something
Old Dec 28, 2005 | 04:00 PM
hardtocope's Avatar
The symbol that kinda looks like that _O_ means ohms right?
Old Dec 28, 2005 | 04:10 PM
vB00STw's Avatar
yes..like an upside down "U"
Old Dec 28, 2005 | 04:17 PM
pclear9061's Avatar
it looksa likea man naaawww it looks like a freaking horse shoe thats what it yes but a round canister style resistor? _n_ that is more like it
Old Dec 28, 2005 | 05:07 PM
hardtocope's Avatar
yea it has to be a round canisiter resistor... it says ohms on it.. i found the wire harness on the panasonic parts list so i think i'm just going to order it.. 35 bucks thoughs
Actually how would you know if the resistor is actually blown or messed up?
Old Dec 28, 2005 | 07:08 PM
Biffno3's Avatar
1023?
Its a resistor, we use that type at work. Its the same as the color coding. 1=1 0=0 and the 2 =10to the nth/ Or simply the number of zeros and 3 is the tolerance as stated above in percentage. So its 1000 Ohms. As for why its on your reciever I have no idea, installed many, but never seen that. What is it connected too? The Power lead, acc, speaker output?
Old Dec 28, 2005 | 07:09 PM
hardtocope's Avatar
it's on my acc wire
Old Dec 28, 2005 | 07:10 PM
pclear9061's Avatar
can you take any pics?
Old Dec 28, 2005 | 07:11 PM
pclear9061's Avatar
oooooo you know what it might be is a filter to stop the waves to so it doesnt have the buzz in the speakers
Old Dec 28, 2005 | 07:15 PM
hardtocope's Avatar
i don't have a camera or otherwise i would take a pic... well i really have no clue on what the hell it is.... it looks looks like this -----( )----- I has a the acc wire crimped on with a metal connector on one side of the wire then the acc wire is crimped on the other side as well.. Its a blue small round soda can type connector with 1023 written on it..
Old Dec 28, 2005 | 07:20 PM
hardtocope's Avatar
my headunit has that thing on the acc wire and it has the fuse for the deck on the battery wire... usually i always see the decks having the fuse in the deck not the wire.. my headunit is weird
Old Dec 28, 2005 | 07:24 PM
pclear9061's Avatar
whats the deck model?
Old Dec 28, 2005 | 07:25 PM
hardtocope's Avatar
panasonic cq-df802u
