remote start??
get something that is "manual capable" meaning that you have to do a certain sequence of actions before you get out of the car, kind of like agreeing that your car is in neutral. I bought a Viper smart start (thanks best buy discount!
) and its nice, but it doesn't support manuals natively. That being said, I couldn't bypass my clutch for some goofy reason, and ended up that i had to take my clutch switch out. kind of sketchy, but thats why I'm the only person that drives it.
tl;dr: Get something made by DEI, and manual compatible.
) and its nice, but it doesn't support manuals natively. That being said, I couldn't bypass my clutch for some goofy reason, and ended up that i had to take my clutch switch out. kind of sketchy, but thats why I'm the only person that drives it.For further convenience with the manual safety procedure, I'd recommend a compustar.
Regardless, I don't know if the pcm is looking for a data signal coming through the clutch switch or not, but believe me. Coming from an electrical engineering student, I could NOT get mine to work under any circumstance.
I was in the process of rigging up a simple switch to open the clutch circuit when any gear was engaged, but I had to back burner that with all the other junk happening in my life.
Mine is a vizion thinks it's made by compustar since the remotes look the same. I have to stop, put the car in neutral while holding in the clutch and the brake, lift parking brake, take foot off clutch and then take foot off brake. The car remains running while I get out and once I close the door it locks the car sets the alarm and shuts off the car. It does not shut of the radio. If I don't follow the order exactly it will not work
lol it doesn't shut off the radio? never heard that...but yea that procedure is better than the dei one where you have to press a button to let it know you're going into manual safety mode, then exit and arm it yourself...compustar's take care of both of those steps.
anyways weird @ that clutch switch. not trying to question your intelligence at all, but what wire are you tapping into?
Sl0wbaltSS
Nov 21, 2018 11:11 PM
DANRICKARD
Oct 1, 2015 12:08 AM
