running speaker wires into front doors
Old Sep 15, 2009 | 04:19 PM
ptrblkz24's Avatar
Hey whats up,
Is it a pain in the ass running speaker wires into the front doors?Im installing a set of jl components and im wondering if it will be a bitch.Its not just a rubber boot right?It has the molex connector correct?Thanks
Old Sep 15, 2009 | 11:20 PM
brickloaf's Avatar
its not hard just kinda time consuming, you have to take off that seal on the outside of the door, i had to run the wire through these little slots on the plastic part thats under that seal.
imo its hard to explain but you will figure it out easy when u start poking around down there
Old Sep 15, 2009 | 11:22 PM
09xfebalt's Avatar
I bought pins from our parts department soldered 12 guage speaker wire to the pins and put them into empty cavities in the door plug. it took about ten minutes per side. its pretty straight forward and easy to do. hope this helps.
Old Sep 16, 2009 | 11:21 AM
Vyse's Avatar
Where did you get the pins from?
Old Sep 16, 2009 | 05:28 PM
09xfebalt's Avatar
any GM dealership if you have power windows ands locks you will need 8 pins totall. go to the dealership and to parts and tell them you need some wiring pins from tray 8 and four pin number 15304717 and four 15304724. if you have manual windows/locks then you need pins from tray 19 and still need four and four of 12191812 and 15304702
Old Sep 17, 2009 | 02:14 PM
jon_k's Avatar
Anyone have pics of the harness? You have to go through the harness?
Old Sep 18, 2009 | 01:21 PM
Vyse's Avatar
Well, when I do door lock actuator or something like that, I just drill out the empty spots on the plug. I like the pin idea. Much cleaner. But, pretty much, you have to go through the door harness to get speaker wire into the door.
Old Sep 18, 2009 | 04:30 PM
bmb17's Avatar
I did it. It was not that bad. I just found a slot around the plug. Took a little time but worth it.
Old Sep 18, 2009 | 07:20 PM
ptrblkz24's Avatar
The pins sound like a good idea,but id rather just run the wire in as one piece.Kinda sucked cause i had to run 2 sets of 12 gauge into the door.1 for the speaker and 1 for the tweeter.I didnt wanna mount the x-over behind the door panel cause i dont want it to get wet.I finished running the wires into 1 door before.It wasnt that bad.I just cut a notch in the connector and fed the wire through it.
Old Sep 26, 2009 | 12:15 PM
Vyse's Avatar
Nice. 2 runs of 12 gauge. I was worried about 2 runs of 14 gauge, but doesn't look too bad.
Old Sep 26, 2009 | 06:09 PM
Spun's Avatar
Nice, where the hell were you about a year ago
Old Sep 26, 2009 | 09:16 PM
SS SCHGD's Avatar
I drilled out the empty pins in the connector, one 14 guage and one 16 gauge went into each door, wasn't to bad. (Tested to make sure two 10 gauge wires would work) Pictures are up on here already somewhere, I will search for them.
Found Thread:
https://www.cobaltss.net/forums/electronics-audio-video-49/new-door-speaker-set-up-51950/
chefhhr
Oct 26, 2015 10:36 PM
roth
Sep 26, 2015 12:16 PM
brickloaf
Sep 25, 2015 09:10 PM
dieGone
Sep 23, 2015 10:20 AM
bustaSS
Sep 3, 2015 09:33 PM
