Shiftlight in the SS/SC?
Old Mar 12, 2008 | 09:47 AM
tryit's Avatar
My friend swares they have a shift light from the factory, is there one? If there is one is there a way to turn it on and off? I rember seeing a light in my old car that looked like a shift light but never turned on.
Thanks,
Nate
Old Mar 12, 2008 | 09:48 AM
JPizzle's Avatar
I have one in my 2.4...
skymynx's Avatar
there is one but it doesnt turn on in the cobalt ss/sc
Old Mar 12, 2008 | 10:01 AM
tryit's Avatar
Is there a way to change that?
Old Mar 12, 2008 | 10:03 AM
steddy2112's Avatar
Nope. It is programmed in the actual guage cluster
2.4 FTW
Drakonen2000's Avatar
Thanks,
Nate
...just get an interceptor....its good stuff man!
Old Mar 12, 2008 | 10:44 AM
SS/SCking's Avatar
X2...
Old Mar 12, 2008 | 10:46 AM
QuikSilverSS's Avatar
The Aeroforce Gauge has a shift light built in and you can set it for whatever you want
Old Mar 12, 2008 | 10:47 AM
freakta's Avatar
its there and it comes on on diff car and not on others. i think hptuners can make it work but im not so sure ive never heard concrete info
Old Mar 12, 2008 | 10:48 AM
lightningfast5's Avatar
the shift lift is on the right side of your fuel gauge.
If you look at the pic you can see it. Its a circle with a plus sign in it.
https://www.cobaltss.net/gallery/sho...searchid=10994
Old Mar 12, 2008 | 11:17 AM
M88ArRamadi's Avatar
yes there is one. But the pcm doesn't use it. I wish there was a way to adjust it.
Old Mar 12, 2008 | 11:19 AM
rallycobalt06's Avatar
it worked in my 2.2 i had. a little dissapointed that it doesn't work on the SS/SC.
Old Mar 12, 2008 | 11:20 AM
http://s107.photobucket.com/albums/m...t=MOV05396.flv
Old Mar 12, 2008 | 11:40 AM
JPizzle's Avatar
Yea @ like 7600 RPM's...
Old Mar 12, 2008 | 11:43 AM
yeah...its not a shift light...its a "your gonna break your ****" light at that point!
Old Mar 12, 2008 | 11:44 AM
JPizzle's Avatar
LOL! Yea, something like that...
What is the SS/SC's redline at? (Where you bounce off of it?)
Old Mar 12, 2008 | 11:47 AM
i think stock is 6.5K (i should know, i drive one, but i dont...lol) and with staging it goes up to 7.2K
Old Mar 12, 2008 | 11:49 AM
freakta's Avatar
i thought stock was 6k? but mine is at 7k right now
eh, it might be.....i have my interceptor set at like 5.8 that way by the time i acount for shift reaction i will be close...i dont look at my tach much
Old Mar 12, 2008 | 11:50 AM
stock is 6.5k stage 2 is 7k and mine is 8k
Old Mar 12, 2008 | 11:51 AM
Psykostevo's Avatar
It will not make it work, because it needs to be programmed into the Gauge Cluster itself. - Like Steddy said.
Yep, it's called an engine overspeed warning. Blown 4-Banger found out that it comes on eventually.....LOL
Last edited by Psykostevo; Mar 12, 2008 at 11:51 AM. Reason: Automerged Doublepost
Old Mar 12, 2008 | 11:52 AM
lol....WARNING: danger to teh manifold!!!!!!
Old Mar 12, 2008 | 11:55 AM
4-banger didn't have head work done. If I had a stock head and internals I would never go over 7k neither
Old Mar 12, 2008 | 07:35 PM
tryit's Avatar
Thanks guys.
Old Mar 13, 2008 | 02:46 PM
Shermen's Avatar
and this light does turn on, its in with the programing of the GM Stage 3. it is either something to do with the nitrous activation or with raising the rev limiter.
