some quick help if you would fellas
I got rid of my ss/sc and went and got just a bone stock 2010 LT cobalt. My question is I want to put an after market head unit in my new balt but I'm not sure what I need. Im not looking for dvd or anything fancy. Really if it has 50w x4 I'd be fine with that since im leaving the stock speakers alone. Only other thing I want in the unit is to have USB and Aux inputs in the front. What would you all suggest for a head unit and what all will be needed to do the complete install? I'll be hooking up my old subs and amp as well but I have all the wiring and fuse and what not for that.
Thank you to anyone that takes their time to give me your input.
Tim
Tim
So basically you will need three parts and its up to you which way you go, the way i suggest is to go the cheap route and dont bother with the expensive module. Pick up one that goes for the Chevy aveo 2007-09 <-- trust me it works.. This is assuming you dont care about your chimes and dont mind getting switched accessory from somewhere else in the vehicle.I got these part images from Best Kits Online but if your from the states most easiest people to get such parts would be Metra Electronics or a bestbuy.. As for decks with usb and aux in the front.. I would go for a decent alpine or Pioneer deck with a good set of triple 4v pre-outs and with the options your looking for as well. You will also get bluetooth with those options you want as well. Hope this helps..
