Speaker selection help
Old Nov 26, 2010 | 09:25 PM
hunthunter123's Avatar
Okay so I have a Kicker ZX550.2 amp and I was wondering if some of you audio experts can help me out on which speaker I should use on it.
I have a Kicker L5 12inch dvc 2ohm that has an RMS of 600 watts
and I also have a Kicker L7 12 inch dvc 2ohm that has an RMS of 750 watts.
So basically which one would be better to run on the amp? Regardless I know that I need to wire the speaker in series so that the amp will get a 4 ohm load. The ZX550.2 has a RMS of 550 watts one channel at 4 ohm.
Old Nov 26, 2010 | 09:28 PM
Also, i know that kicker amps are normally rated at a higher wattage than what it says. For example my ZX350.4 running my mid range speakers is rated at 400 something watts. Sadly I lost the sheet of paper that tells the EXACT amount my ZX550.2 is pushing.
Old Nov 28, 2010 | 04:08 AM
EmperorJJ1's Avatar
it would match with the L5 the best but the L7 might be louder even thou its under powered. Id put in the L5 tune it properly then try the L7 with the same settings and use whichever one is louder
Old Dec 17, 2010 | 07:41 PM
Thank you for your help, sorry it took so long to reply.
brickloaf
Sep 25, 2015 09:10 PM
speedlimit
Site Development and Help
Sep 25, 2015 08:04 AM
dieGone
Sep 23, 2015 10:20 AM
