Speakers not working with new head unit
Old Jan 17, 2008 | 11:15 PM
roccobladr's Avatar
theres a pic if any of u guys were wandering
Old Jan 18, 2008 | 03:21 AM
EmperorJJ1's Avatar
Originally Posted by roccobladr
so if i get an aftermarket amp, it would allow me to control the sub level directly from the head unit?
yes... the reason why u cant control the sub directly with the stock amp is not only because it wasnt set up that way but both the 6X9s and sub use the same channels on the amp
Old Jan 18, 2008 | 09:51 AM
roccobladr's Avatar
gotcha. so should i just get an amp for the sub? or do i need one for the sub and one for the toher stuff?
Old Jan 18, 2008 | 03:50 PM
EmperorJJ1's Avatar
you can do either. but i recommend getting a new sub as well if your getting a new amp
Old Jan 19, 2008 | 01:07 AM
Spun's Avatar
I second that, theres no comparison, well worth it
Old Jan 19, 2008 | 01:31 AM
roccobladr's Avatar
my brother has an extra sub i can use. can i hook them both up somehow? id hate to have the stock one just sit there and do nothing
Old Jan 19, 2008 | 04:27 AM
EmperorJJ1's Avatar
what size is the new sub... if its a 10 you should see if it fits in the stock box... if its a different size then your going to want to choose either stock or aftermarket sub. Mixing sizes of subs in a car will sound like ass (may be a bit louder but due to cancellations not as much as you would think)
Old Jan 20, 2008 | 01:33 AM
Preowner's Avatar
The stock sub box is removable.
But if you decide to just get an amp and use the stock sub; keep in mind that it uses dual 2 ohm coils. Depending if your amp of choice can handle that or not, you may need to wire them in series for a single 4ohm load.
Old Jan 20, 2008 | 04:57 AM
EmperorJJ1's Avatar
and you will blow it within a month or so i can guarantee it
Old Feb 6, 2008 | 01:54 PM
06BrandonSS's Avatar
Just read the thread and had the same problem but did the blue to blue/white wire and it works great, thanks for the info everyone!
ineedacobaltss
Nov 7, 2015 02:25 PM
HEATON
Oct 16, 2015 07:21 PM
Sep 28, 2015 12:51 PM
