ss/sc same harness as lt?????
i've got an ss/sc and had my indash in an lt before. to make the stock sub to work will i need a different harness than i had before. im trying to do this tonight so somebody pls give me any answer.
thanks
cody
thanks
cody
when i had my avic-d3 put in all i needed was a wiring harness and the double dash thing, i believe the sub wires are already wired into the existing harness so you just have to put it in and your set....
depends on the yr. all 05-06 cars use the same harness. Then all 07+ pioneer have a module harness and al 07+ non pioneer have a module harness but all 07+ have a "universal" cheap harness
I have an 06 lt harness? So my pioneer ss sub will work through my kenwood ddx512 headunit?
I know all i need is a harness im just wondering if my ss sub will still work through my old lt harness
Last edited by Maupin SS/SC; Jan 27, 2010 at 01:43 PM. Reason: Automerged Doublepost
should be the same... do u have a high pass x-over in ur deck?
the stock deck takes the 4 full range inputs and sends it to all the 7 speakers in the car including the sub. If its not working then all the speakers shouldn't work
I have some filter it doesn't say weather its high or low though. I set it at 50. I have a question though. This hu is pissing me off, and I'm bout to go back to stock. My car is an 08. Is it possible to use an 09 radio with the usb and bluetooth? Will the bluetooth work? If this works, do you know if the usb will play music from the ipod, and charge as well??
where is the amp turn on wire thats my problem i figured there was one i hooked it all up and it turned on a had no sounds. thats explains ill go ahead and call myself a n00b dont worry about it.
i had a freak out the other night when it wouldnt play (:
