steering wheel controls
Old Jan 10, 2010 | 11:29 AM
chitala383's Avatar
the other day i installed my pioneer p4100 head unit. i got the pac swi, wired it up, programmed it and it worked fine at first. later on in the day it seemed to work when it wanted to. sometimes i could use my steering wheel controls and sometimes i couldnt. then the following day it stopped working all together. i pulled my head unit out to reprogram the pac and it wont even let me program it. i'll turn the car on, hold down the program button, let it go and the led stays lit. but when i push a button on the steering wheel it doesnt register and wont program anything. any ideas? could i have gotten a bad pac? should i just get a new one?
Old Jan 10, 2010 | 11:31 AM
originaladrian's Avatar
there all a bit spotty, none of them are perfect. I have had mine for about 2 years and pretty much 90% of the time my wheel controls will work but sometimes they get a bit messed up till i can turn off and on my car.
you can try and reprogram it but its a known problem
edit- reread your post. if it wont let you reprogram it then call them and get a replacement
Last edited by originaladrian; Jan 10, 2010 at 11:31 AM. Reason: Automerged Doublepost
Old Jan 10, 2010 | 11:48 AM
Zdeuce4's Avatar
maybe the steering wheel control buttons are broken. i had mine replaced under warranty twice for not working when i didnt have my pioneer p4000
Old Jan 10, 2010 | 12:30 PM
bmb17's Avatar
My PAC SWI is a pain, it only likes to work when it wants to. If its not going into programing mode it sounds like you need a replacement pac swi. I wish there was a better option for steering wheel controls.
Old Jan 10, 2010 | 09:48 PM
chitala383's Avatar
ok, so it looks like i'll get another pac swi and see what happens. if the next one doenst work i guess i'll live without steering wheel controls
Old Jan 11, 2010 | 08:44 AM
chitala383's Avatar
also does anyone know how to bypass the p4100 so i can play a dvd while driving?
Old Jan 12, 2010 | 04:49 PM
chitala383's Avatar
anyone??
Old Jan 12, 2010 | 05:17 PM
Zdeuce4's Avatar
ground that wire thats connected to the parking break to a powered switch
Old Jan 12, 2010 | 05:38 PM
raptors_67's Avatar
How and why would you ground it to a powered switch? Perhaps a switched ground circuit of some sort?
Old Jan 12, 2010 | 05:40 PM
Zdeuce4's Avatar
lol i mean ground it to a switch. so u can turn it off and on when needed. haha.. my bad on the wording.
Old Jan 12, 2010 | 05:44 PM
ryanstammler's Avatar
Wink
thats what the guy who installed my avic-d3 did, the switch works like a charm
Old Jan 12, 2010 | 06:44 PM
chitala383's Avatar
explain a little more please. where should i get the power for this switch from? are you saying i could just run a wire from say the wiper fuse to a switch and connect the parking brake wire from the head unit to the other side of the switch? is that correct? or am i wrong
Old Jan 12, 2010 | 11:02 PM
Zdeuce4's Avatar
u need a switch but u gotta ground it out on something that the radio is already not grounded on. ive been meaning to do it but im too lazy
Old Jan 12, 2010 | 11:05 PM
bmb17's Avatar
They are saying to hook it to ground but put a toggle switch in the line. If you just hook it to ground the videos will not play you would need to turn the toggle off then on and then the videos will work I think. I would recommend using a relay. That is what I used for my p4000. This might help you out http://www.youtube.com/watch?v=g8HCcNy9QQQ
Old Jan 12, 2010 | 11:21 PM
Zdeuce4's Avatar
my friend's been tryin to hook me up with a permanent fix for the p4000.. he ordered it 3 times and they keep backordering it. im almost ready to just do it myself.
Old Jan 13, 2010 | 11:55 AM
chitala383's Avatar
oh yes that video helped me out. exactly what i was looking for. kick ass! now i just gotta get unlazy and pull my head unit out and do this.
Old Jan 14, 2010 | 02:58 AM
EmperorJJ1's Avatar
**** a relay dude... get a 2 prong switch hook one side to ground and one to the parking brake and done
Old Jan 14, 2010 | 09:24 PM
chitala383's Avatar
yeah but then i'd still have to flip the switch. **** doin things for myself i want them done for me! haha
Old Jan 14, 2010 | 09:35 PM
EmperorJJ1's Avatar
and whenever your pulled over for having video playing visible to the driver and the cop says go ahead and turn it on and ill see if its playing video or not... automatic wont be so nice in that situation would it. Ive seen the tickets and they trump alot of stuff out there, tint, lights,hid, some speeding
Old Jan 14, 2010 | 10:49 PM
Zdeuce4's Avatar
thats when u tap the display off button.
Old Jan 18, 2010 | 07:43 PM
chitala383's Avatar
Genius!!! haha
Old Jan 18, 2010 | 08:58 PM
Zdeuce4's Avatar
i do it all the time... especially when i see unsavory characters outside my car. dont want em gettin any ideas.
Old Jan 30, 2010 | 05:48 PM
ThiZo_19's Avatar
jj today i was thinking instead of fliping switch on and off, or off and on wtvr order it was i dont remember when i had my p4000 in my civic...i obviously can put a relay. but then thinking more i was like (i always had to switch it TWICE) and a relay will turn on with the remote wire obviously...but its its a naturaly opened relay it will just close the circuit giving it a constant ground...now iunno if it would work cuz i usually always pressed the switch twice anyways maybe i always had it grounded, then when i wanted to watch id unground and ground so IUNNO sorry for the retarted explanation ill try with a relay seeing as how i have thousands of them lying around but iunno im lazy as **** when it comes to this ARG
Old Jan 30, 2010 | 08:34 PM
bmb17's Avatar
A relay will work great
Old Jan 31, 2010 | 10:26 PM
EmperorJJ1's Avatar
a relay should work just fine but the reason i prefer the switch is control and ease of installation. a switch is easy... a relay, not so much
Solaris99
28
Mar 15, 2017 01:22 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
TedSS
26
Oct 10, 2015 04:30 PM
