Sub Question
Old Mar 29, 2008 | 09:49 AM
HidKidSS's Avatar
Sub Question
whats going on everyone....so im looking into getting the jl w7 13.5 sub an running that with the jl 1000/1 or 1000/1 v2
i just got rid of my 2 audio pipes 1600watt subs with a crunch 1600watt class d amp
from videos on youtube i see that the w7s are no joke...now heres the question is one enuff or should i get 2?
i know someone on the forums are running 2 w7s in a custom cf box but dont member who
so will one be enuff or should i just over do it an get 2?
Old Mar 29, 2008 | 10:06 AM
Bumpin Balt's Avatar
Dude, 1 will make you deaf in no time! LOL
Old Mar 29, 2008 | 10:18 AM
HidKidSS's Avatar
haha yah but i like over doing it sometimes tho but whats the diff between the 1000/1 n the 1000/1v2? i looked at the specs they both seem the same in looks an performances specs but the prices is diff tho lol
Old Mar 29, 2008 | 10:30 AM
Here's some info on the v2 features. The v2 amps will put out the same wattage no matter what impedance your speakers are. The w7 subs are 3 ohm, so if you use an amp that is rated at 1000watts RMS@2 ohms, you're going to get a lot less than that with 3 ohm sub. The v2 series is definitely the way to go for a w7.
http://mobile.jlaudio.com/products_a...hp?page_id=221
Old Mar 29, 2008 | 10:42 AM
HidKidSS's Avatar
yah the 2nd spec listing says 1000watts at 1.5ohms
Old Mar 29, 2008 | 11:03 AM
Joewit's Avatar
13w7 is 1.5 ohm wired correctly and slash v1 and v2 both put out 1000 watts at any impedance 1.5 to 4. So with the 13 you dont really have to stick with a jl amp, and you can definetly get a better sub for the price of a w7 unless you're getting a deal on it like i did.
Old Mar 29, 2008 | 11:14 AM
HidKidSS's Avatar
what kinda deal did u get pm me if u like or just talk bout it in here either or
which sub is better then the jl w7?
Old Mar 29, 2008 | 02:16 PM
I thought all w7's had a single 3 ohm voice coil. The 13w7 has dual 1.5 ohm voice coils, which means it can be wired in series to put a 3 ohm load on an amp or in parallel to put a .75 ohm load on an amp. I don't think too many amps can handle a .75 ohm load, so you will need to wire it in series. There is no way to wire a dual 1.5 ohm sub to end up with a 1.5 ohm load that I am aware of.
The 13w7 is rated at 1500watts RMS. An amp that puts out 1000watts RMS will not allow you to get the most out of the 13w7. You would be better off going with a 10w7 or a 12w7 (1000watts RMS). Even an 8w7 will give you more than enough bass to make your car rattle like crazy and it requires less power (500watts RMS). I heard an SQ system with a single 8w7 and it had plenty of punch without being overwhelming and painfully loud. I have a single 10w6 in JL's H.O. enclosure and it keeps me satisfied. I may try an 8w7 in the same box, but I would have to make an adapter ring to mount it in the 10" hole.
Last edited by Bumpin Balt; Mar 29, 2008 at 02:16 PM. Reason: Automerged Doublepost
Old Mar 29, 2008 | 11:40 PM
Joewit's Avatar
I just got lucky and got a brand new 12w7 w/ the H.O wedge for 395 on ebay, I wouldv'e gone with a Digital Designs if I was planning on spending alot of money. Whats a 13w7 like 550 on ebay?
Old Mar 30, 2008 | 01:55 AM
EmperorJJ1's Avatar
DD is alot better then JL all the way around and they arent as bad as peeps on the net make them belive unless your looking at Z series stuff
its all in the box... make sure you get a good box and 1 will be enough
Last edited by EmperorJJ1; Mar 30, 2008 at 01:55 AM. Reason: Automerged Doublepost
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
