sub question
Old 09-20-2009, 08:41 PM
mrkrackie's Avatar
sub question
So i have two ideas not sure of whats easier... 1. But another stock pioneer sub and put it on the otherside of my trunk. A. would i need to buy another amp? or could it run of the one that the other ones running off of? B. is it possible to mount it on the otherside?
2. To buy a 12" polk sub and put it in. A. can you hook it up to the stock subs wires? B. Can it run off the stock amp? or will i need a new one? B2. if i need a new amp can it use the wires the stock ones using now?
Old 09-21-2009, 04:49 AM
Spun's Avatar
Easiest way to get this done,
Get an LOC (line outpout converter)
Get a new sub/box (the polk one your talking about will do in this case)
Get an amp that matches the power that the sub needs.
disconnect the stock sub
wire in your new sub
(not using the stock wires)
Old 09-26-2009, 12:23 PM
Vyse's Avatar
I would just get a new sub and amp. It will be a big difference in performance. Here's what I did:
I just used the factory sub as a template and built off of that.
A little MDF and fiberglass and some elbow grease
If you aren't comfortable doing it yourself, any good shop can do this. Good luck
Old 09-26-2009, 05:54 PM
Spun's Avatar
Is that all wood, or is there glass in there?
One more question, is that the template for the Cobalts back deck lid hanging on the wall behind you?
Old 09-28-2009, 02:15 PM
Vyse's Avatar
.75" MDF front and back w/smaller pieces cut for bracing
Fleece stretched to cover the odd shaped top and bottom.
Fiberglass resin applied to the fleece and then 2 layers of woven fiberglass cloth finish it off.
I trimmed off the excess with my airsaw and a metal blade after it had cured. Then I sanded it up and it was ready for carpet. As for the templates on the wall, nothing for a Cobalt.
brandon04
10-21-2015 07:04 AM
patooyee
10-15-2015 05:11 PM
Iceberg
09-29-2015 12:33 PM
Extremespeed
09-29-2015 04:34 AM
Iceberg
09-28-2015 01:31 PM
Quick Reply: sub question
