subs with stock headunit?
Old Apr 8, 2008 | 06:02 PM
konartis91's Avatar
how can i wire up subs and an amp to the stock head unit?
Old Apr 8, 2008 | 06:14 PM
Touch's Avatar
Yes i did the same thing and it works good.
Old Apr 9, 2008 | 04:55 AM
EmperorJJ1's Avatar
line output convertor... check out the FAQ
Old Apr 9, 2008 | 03:10 PM
Gotenks's Avatar
I did the same thing too
Old Apr 9, 2008 | 03:17 PM
Pontiac.G5's Avatar
except with the crossover you can put in a line output converter like emperor siad
Old Apr 13, 2008 | 07:18 PM
Corp17's Avatar
I did mine without a line output converter, reason was because the one i bought simple didn't work, so i basically tapped into the rear speakers and ran the lines into my amp out into the sub, it works great. I do recommend however if you do have a working line output converter (about $20 at Best Buy), then use it, its suppose to make the sound crisper.
Old Jun 3, 2008 | 08:29 PM
blackbalt sport's Avatar
Got a question for ya Corp17. I did the same thing as you except I get a popping sound from my subs anytime I open the door unlock doors turn on key and anything like that. Any idea what the problem is here? My amp doesn't have a remote turn but high level sensing I think its called.
Old Jun 3, 2008 | 11:13 PM
balt21's Avatar
if your amp has high level inputs you can splice those directly into your speakers and do not need the line output converter.
hmm i had a line out converter hooked up for like 2 hours till realized my amp had the high level inputs; imo it sounds better with the high levels than it did with the line out converter.
Old Jun 4, 2008 | 02:55 AM
EmperorJJ1's Avatar
replying in ur thread
Old Jun 5, 2008 | 11:12 PM
jacobmprater's Avatar
buy a LOC and wire it up and run your amp and sub. its easy and self explanatory if you read the instructions.
Supercharged06SS
Dec 11, 2022 04:47 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Oct 13, 2015 09:32 PM
Stuff
Oct 1, 2015 05:47 PM
c_m_shooter
Sep 27, 2015 04:40 PM
