Subwoofer Help
Old Aug 19, 2009 | 02:36 PM
DarkCobalt13's Avatar
Subwoofer Help
My infinity kappa isnt hitting at all. I checked the fuses and connections, everything seems to be ok. The amp is powered up and running. The coils on the sub are good and the cone is not broken. Recently it would hit a few times an then stop. A minute or so later, hit a couple more times and stop...... Anyone got an idea where I should look next?
Old Aug 19, 2009 | 02:38 PM
BPacak's Avatar
Vtec Rep
That happened to my friend like it would go on and off and i guess his amp was fried. hope its just something likke a wire or fuse that u missed. did u check the ground?
Old Aug 19, 2009 | 02:48 PM
yeah, grounds were ok...... guess im gonna have to check the amp out and see if I can find the issue
Old Aug 19, 2009 | 06:16 PM
brickloaf's Avatar
does the amp stay on the whole time, or does it cut off when the subs wont hit?
soemthign similar also happened to me right before my stock radio went out...
but if you havent checked, id make sure all the speaker wires are in tight, on the amp and sub.
Old Aug 20, 2009 | 04:26 AM
EmperorJJ1's Avatar
when it stops push the woofer in and see what happens
Old Aug 20, 2009 | 09:01 PM
mikelpn's Avatar
x2 sounds alot like what happened to my sub...
Old Aug 20, 2009 | 10:00 PM
brickloaf's Avatar
bottoming out i guess?
Old Aug 22, 2009 | 01:17 AM
Spun's Avatar
I'd say blown sub is what there getting at.
When you push on it its either going to be loose as hell and sound like nails on a chalk board, or its going to be stiff and feel like even if you stood on the damn thing it wouldn't move
Old Aug 22, 2009 | 04:22 PM
The coils are fine, the amp stays on, connections are tight. The one thing i did notice is my box terminals were melted. Got some new today but i need to get a trunk mat or something to support the box for the trunk cause its been in my back seat since my trunk mat split and the sub kept falling over...... Im thinking the terminals melted and were no longer making contact between the amp's output wires and the boxes internal wires. Question is, why did they get so hot?.......
Old Aug 22, 2009 | 04:33 PM
Spun's Avatar
Your terminals melted???
WOW
Can't say that I've ever seen that before.
In the process of your box getting tossed around could it have come in to contact with the power/ground wire?
Old Aug 23, 2009 | 11:46 AM
dejo's Avatar
make sure you dont have one of the coils wired out of phase with the other coil or the woofer wont move at all and seem like the amp is dead
Old Aug 23, 2009 | 06:41 PM
Replaced the terminals, removed the capacitor, got new/larger amp to box terminal wires and put it all back in the car. Everything seems to be ok now. Im gonna keep an eye on it.
The positive side terminal was melted to the point where the wire was melted to the metal connection inside the housing...... Kinda scary considering the amount of heat that would take!
Old Aug 23, 2009 | 09:37 PM
nicksredline's Avatar
well not rilly heat as much as an ark... sounds like it was grounding out and arcking( would cause the no sub's working and the fried connection problem.
Old Aug 23, 2009 | 09:41 PM
The ground is and has been tight. Thats the first thing I checked
Turbo6
Aug 27, 2015 08:37 PM
bamfnss
Jul 11, 2006 05:02 PM
averagewhiteboy
Jul 4, 2006 09:19 PM
BlilBT
Jun 14, 2006 08:51 AM
Uneek
Nov 9, 2005 06:04 PM
