Subwoofer Help!
Old Oct 14, 2009 | 06:57 PM
S-S/S-C's Avatar
Subwoofer Help!
Im looking at a alpine type r at 4 Ohm....What does the 4 ohm mean?? and can it be wired to a mono block amp and work to its full potential??
Old Oct 14, 2009 | 07:26 PM
c4w18's Avatar
ohms are a measure of electrical resistance. Basically, you'll get more power output from your amp with less resistance, but if not enough resistance is provided it will cause a problem as well. What are the specs on your amp? it should tell you what power it outputs at 2 ohms and four ohms on a single channel.
Old Oct 14, 2009 | 07:49 PM
S-S/S-C's Avatar
Heres the specs: 12" subwoofer with dual 4-ohm voice coils
# Kevlar reinforced pulp cone with Santoprene rubber surround
# Cast aluminum frame with perimeter venting
# Frequency response: 25-500 Hz
# Power handling: 200-500 watts RMS (250 watts per coil)
# Peak power: 1,500 watts
Can 2 of these subs be hooked up to a 1000 watt Kicker mono amp?? and still work to there full potential?
Old Oct 14, 2009 | 08:16 PM
c4w18's Avatar
most likely yes, but i need specifics on the specs of the amp....that 1000 watts usually is a bullshit marketing tag...
Old Oct 14, 2009 | 08:21 PM
S-S/S-C's Avatar
Ohh alright..heres the specs for the amp:# ZX Series Class D Monoblock Car Amplifier
# RMS Power Rating:
* 4 ohms: 500 watts x 1 chan.
* 2 ohms: 1000 watts x 1 chan.
# Max power output: 1000 watts x 1 chan.
# MOSFET power supply
# Wired remote bass level control included
# LED power and protection indicators
# Tuned Bass EQ (0-18 dB bass boost at 40 Hz)
Old Oct 14, 2009 | 09:24 PM
c4w18's Avatar
that should work well but i'm not sure if the resistance would be too high if it has two coils 4 ohms each....i'd ask someone like emperor how that would work out...i'd give it a shot though, power looks like it matches up well
Old Oct 14, 2009 | 09:57 PM
brickloaf's Avatar
im not sure if type R's are dual 4 ohm or single 4 ohm, but the amp your looking at appears to only be 2 ohm stable, so if you do get 2 dual 4 ohm type r's it will not be compatiable with the amp because it will be wired down to 1 ohm, but if you get 2 single 4 ohm subs then both wired together will be 2 ohms, which would be perfect for your amp.
Old Oct 15, 2009 | 02:48 AM
EmperorJJ1's Avatar
as he posted its a dual 4. meaning the single sub would be 2 ohms
hey post some model numbers man help us out... i can assume ur talking about the 1000.1 and dual 4 type r if thats the case they dont match up. amp is too big for the sub and will blow it
Old Oct 15, 2009 | 02:33 PM
Spun's Avatar
That amps only good to 2 ohms
If you hook 2x4ohm DVC subs you woyld have to loop it around to run at 4 ohms, thus only getting 500 watts out of the amp
Find an amp thats 1 ohm stable or get SVC subs
Old Oct 15, 2009 | 04:04 PM
Vyse's Avatar
Type Rs are great subs, in my opinion. I have a 10" for my current build in my Cobalt and I had a 12" in my Camaro. An amp for that sub that I've had good success with is the Alpine PDX 1.600. Throw that sub in a ported box and run that amp and you'll be a happy man.
Old Oct 15, 2009 | 06:51 PM
S-S/S-C's Avatar
Heres the link to the subs:
http://www.hifisoundconnection.com/S...id/0/SFV/30046
And Heres the link to the Amp:
http://www.sonicelectronix.com/item_...+ZX1000.1.html
Can the subs be wired down to 2 ohms and be compatable with the amp while working to there full potential???
Old Oct 16, 2009 | 02:35 AM
EmperorJJ1's Avatar
no 2 4 ohm subs can only be 4 ohms or 1 ohm
you would need 2 dual 2 ohm subs
Turbo6
Aug 27, 2015 08:37 PM
bamfnss
Jul 11, 2006 05:02 PM
averagewhiteboy
Jul 4, 2006 09:19 PM
BlilBT
Jun 14, 2006 08:51 AM
Uneek
Nov 9, 2005 06:04 PM
