For those with the base stereo
Old Jan 12, 2006 | 10:17 PM
Steeltown Pursuit's Avatar
I have a base model Pursuit - the one without the MP3 factory deck.
I was wondering if it would be worth it to change the factory speakers... I find the fronts sound fine, but the rear factory 6 x 9's sound a little muddy and distort very easily.
if I change out the factory rear speakers and keep everything else stock... will there be a noticeable difference?
Old Jan 12, 2006 | 10:24 PM
wikkymaster's Avatar
maybe a little, i think most of the quality comes from the cd player itself rather than the speakers, change the deck you should notice a bigger difference then just tchanging speakers
Old Jan 13, 2006 | 09:22 AM
Bandit2941's Avatar
No. Speakers make a much bigger difference than the head unit. You won't get any good sound out of them crappy ass paper speakers with a better head unit. To the OP, yes if you replace your speakers it will sound much better.
Old Jan 13, 2006 | 09:36 AM
RACIN_RANDY's Avatar
the speaker is were the sound comes' from, so changing the speaker defenitly will make for a better sound. the head only sends the sound, not makes the sound.
Old Jan 13, 2006 | 10:07 AM
CleanNFun's Avatar
"the head only sends the sound, not makes the sound"
I'm just going to assume you were tired when you wrote that
Old Jan 18, 2006 | 04:33 PM
crazydemon's Avatar
Sh*t in -> Sh*t out.
Changing either won't make a worthwhile difference. New deck may give you the option to play MP3s and a nicker look/feel, but It will most likely not improve the sound quality.
Changing the speakers on the other hand won't make a significant difference either because the signal produced by the deck is heavily equalized and fairly weak; not acceptable for any decent speaker.
The whole thing is really a package, deck, amp and good components is the only way to
Old Jan 20, 2006 | 04:09 PM
thanks for the info everyone...
my deck ended up showing signs of the ERR message and the cd getting stuck and the time starting to change on it's own.
I ended up getting the whole deck replaced under warranty, but ended up just getting another exact replacement and not the up model one as others have posted in other posts.
I was wondering, is the deck warranties under the bumper to bumper warranty or is the deck on a shorter warranty period? I'm a little worried I will run into the same ERR issues again and I do want to get it covered under warranty if it happens again... any ideas?
Old Jan 21, 2006 | 08:54 PM
update - I just got the deck replaced because of the ERR issues and guess what.. 2 days later again the cd gets stuck and I get the ERR message again!
I'm gonna take the car in again and see if I can get them to give me an upgrade to the mid level stereo....
footballplaya3k
Sep 30, 2015 09:39 PM
Turbo6
Sep 24, 2015 04:15 PM
Cptnslo
Sep 24, 2015 09:32 AM
Builttss
Sep 21, 2015 04:29 PM
