Trunk issue
Old Jun 11, 2009 | 03:13 PM
Red Devil 07's Avatar
Trunk issue
i have an issue, my trunk wont open from the button under the dash and from the key. does anyone have an idea whats wrong?
Old Jun 11, 2009 | 08:46 PM
08G5GT2.4L's Avatar
Check your fuses....Im not being a dick here, its a real possibility since neither the remote or button works.
Old Jun 11, 2009 | 09:05 PM
ctcsoccer7's Avatar
your forget , he also said the key wont work!
Old Jun 11, 2009 | 10:24 PM
by key i ment remote, the key chain for the alarm and doors. It only works with the key and i works when you pull the tab on the back, I check the fuse it was good and i could hear it click when i pushed the button and wit the remote. my friends got a cobalt also and i asked him to show me if it did it in his car and when he hits his button or the remote it clicked also. so the fuse is fine just why wont it work wit my remote or key
Old Jun 12, 2009 | 01:27 AM
ctcsoccer7's Avatar
actuator or relay issue....could possibly be bad!
Old Jun 12, 2009 | 01:34 AM
EmperorJJ1's Avatar
its clicking so its activating.... meaning no electrical issue... latch is probably misaligned or something
but if hes hearing the click when he tries to pop it it couldn't be the relay or anything like that right? not sure if the stock latch uses an actuator but if so that could be it
Last edited by EmperorJJ1; Jun 12, 2009 at 01:34 AM. Reason: Automerged Doublepost
Old Jun 12, 2009 | 01:58 AM
ctcsoccer7's Avatar
ive seen both actuator and relay driven , im not completely sure on his but if the relay can click but not put out voltage to pop the trunk, same with the actuator, if its going bad an actuator will sound ok but not move its total path of travel, but your idea of being misaligned is probably more on the right track depending on what year it is.
Old Jun 12, 2009 | 12:34 PM
Maetrix's Avatar
Take a look at the latch.
Try working some lube into it
It could just be gummed up.
Not saying that this is definitly the answer, but it's cheaper to try first.
Old Jun 12, 2009 | 12:36 PM
jlong3382's Avatar
Do you have a warrenty?
And wrong section. Sry.
Old Jun 13, 2009 | 01:22 AM
Toasted08cobalt2.2's Avatar
I have been having this same problem with my trunk for months now, but once in a blue moon it wants to work then after a few times of it working it goes back to neither button working. I thought it might be a short somewhere in the car or a wire that might be lose .
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
SlowSaturn
Sep 28, 2015 11:03 AM
grampss
Sep 27, 2015 08:51 PM
c_m_shooter
Sep 27, 2015 04:40 PM
