Turn off auto headlight feature
Old Jan 4, 2013 | 03:57 AM
ThePie's Avatar
Exclamation Turn off auto headlight feature
Not sure if this is in the right section first of all.
On my 08' Cobalt I would like to turn off the auto headlight feature for when it gets dark the headlights don't automaticaly come on along with having those running lights off all the time as well. I want to be able when to choose when I want my headlights on like in the older cars.
Old Jan 4, 2013 | 04:02 AM
vahdyx's Avatar
When I had HIDs I just pulled the fuse for DRL, as for auto lights not sure. But to turn off the auto lights when you unlock your car etc. you do that through the DIC
Old Jan 4, 2013 | 06:25 AM
buildmeanempire's Avatar
Yep. 10 amp fuse under the hood and for auto lights when it gets dark, twist the knob down on the one on the left. Don't know if it stays like that or if you have to do it every time you start the car though.
Old Jan 4, 2013 | 09:38 AM
tomj77's Avatar
That or put a switch on that little photo cell on ur dash, the round one in the front that's for the auto lights, ya snip the wire and put a switch on it so u can turn it on or off.
Old Jan 4, 2013 | 09:56 AM
Sox-Fan's Avatar
Got Brakes?
Turn the headlight switch on your turn signal stalk backwards toward you and you'll see Automatic Headlights OFF on your DIC and your headlights will turn off.
No need to pull fuses or cut your wiring harness, lol.
Old Jan 4, 2013 | 10:02 AM
umrdyldo's Avatar
Without putting a switch on the light sensor there is no way to disable this except by the arm controller. I know the U.S. cars are this way for legal reason. I remember the canadians being different, but that may have changed.
Old Jan 4, 2013 | 10:03 AM
Wert842's Avatar
Then turn off the car and walk away from it like a boss. Comeback 3 hours later and realize you're parking lights are on. You'd still have to pull a fuse no matter what.
Old Jan 4, 2013 | 10:09 AM
Sox-Fan's Avatar
Got Brakes?
what?
Old Jan 4, 2013 | 10:17 AM
Wert842's Avatar
When you turn that on you're turn signal, your parking lights still come in. It doesn't fully eliminate all the lights.
Old Jan 4, 2013 | 01:27 PM
prevsrt4owner's Avatar
This.
Old Jan 4, 2013 | 01:28 PM
mkulrey13's Avatar
Yes it does... wtf are you talking about willis?
Old Jan 4, 2013 | 05:50 PM
ThePie's Avatar
Well when I tested this by turning the stick back on the left to turn off auto lights it does turn off all headlights. But as soon as I put the car into drive they come back on. Auto off only works in park.
Old Jan 4, 2013 | 05:59 PM
LS6Rally's Avatar
those are DRL's Daytime running lamps.you would have to pull a fuse or relay out to disable those.
Old Jan 4, 2013 | 06:11 PM
Wert842's Avatar
I can tell you right now on my 09, when I turn the auto lights off soon as you take the car out of neutral my cars parking lights come on. Headlights aren't on, but parking lights are.
Old Jan 4, 2013 | 06:14 PM
N1ckateen's Avatar
he didn't say turn it up to the middle option where parking lights are supposed to be on. he said turn it back so that it still flips back into the auto position, it just pops up with the message AUTO LIGHTS OFF on the DIC and ur headlights turn off. I think there was some confusion. hope that cleared it up lol.
Old Jan 4, 2013 | 06:18 PM
ThePie's Avatar
Are there pictures or a guide for doing this thing with the fuses and such. It would be nice to not have the DRL on at all, and also If I could have it so I would need to use the switch on the left to turn my headlights on and off wither its day or night.
Old Jan 4, 2013 | 10:52 PM
z062007vette's Avatar
I'll try to take a video sometime this weekend.
Old Jan 5, 2013 | 03:53 AM
EmperorJJ1's Avatar
mas puto
Old Jan 5, 2013 | 09:33 PM
kzak104's Avatar
only works when my ebrake is on, once i release the ebrake they come back on. i took my drl fuse out a while back.
Old Jan 5, 2013 | 09:42 PM
ThePie's Avatar
Ok thanks please do and post a link or something. Thanks again.
06MetallicBalt
Jul 20, 2025 08:47 PM
Solaris99
28
Mar 15, 2017 01:22 PM
riceburner
Oct 2, 2015 05:47 PM
roth
Sep 26, 2015 12:16 PM
