Upgrade my sub in stock enclosure
I'd like to upgrade my sub but keep the same enclosure for space reasons.
If I could get some recommendations on the sub and amps and any other equipment I might need to replace the stock sub I would appreciate it.
Thanks
Thanks
Look at the kicker cvt10-2 or RF p3sd410 for something with more spl and do the polk mm1040 for more sq. All priced about the same and should fit.
As far as amps try a kicker 10zx300.1 or soundstream rub1.400. Both inexpensive and nice amps that will power any three of those subs.
Dont forget about your amp wiring and if you have a stock radio your gonna need a line output convert (loc)
is there a website you would recommend buying from ?
What are the differences between these subs?
http://www.amazon.com/Polk-Audio-AA3...8341410&sr=8-2
http://www.amazon.com/Rockford-Fosga...1&sr=8-1-fkmr1
Thanks again for your help
How about this guy's write up and install instead of using a LOC?
https://www.cobaltss.net/forums/show...tock+subwoofer
Anbody have opinions on this?
Is there a How-To and pictures on this procedure as I've never done a stereo equipment install before
swapping your stock sub out for another 10" and a aftermarket amp on the stock head unit
did a ton of searching and only found the one that doesn't use the LOC
any help would be appreciated
Yea i did have to cut the box some to get the speaker basket to fit in.
I just cut it with a sabre saw. You can also use a Dremel tool.
Here is the box ready for the sub after i cut the notches.
The sub model is 15-SC10S4
I paid $270 for it from a local stereo shop.
Be advised there is no authorized internet dealer's for Memphis. So if you find it online it will not have a warranty.
Here it is with the sub installed.
The LOC your just need to tap into the rear speakers from in the trunk.
For a remote turn on for the amp i used a fuse tap in the sunroof fuse.
Even if you don't have a sunroof it still only has power when the key is on.
The amp I bought used off craigslist by someone local that was selling it.
I have the amp mounted to the back of the seat.
I'll get a pic tomorrow of how I mounted it. I'm at work now and the balt is at home.
