using my own sub in place of the factory pioneer
Old Jan 23, 2010 | 03:29 PM
U-town SStrong's Avatar
so i traded in my cavi and got me an '07 cobalt ss/sc with the pioneer system installed, how easy would it be to install the sub and amp from that i already have using the pioneer setup? would it be as easy as pulling out the wiring for the old sub (is there already some rca's back there to the pioneer sub) and jacking it right into the amp i've got. also how easy is the car to run wires throughout? i know a lot of the cavi trim easily snapped in and outa place which made installs super easy, how easy is the cobalt to work in? thanks for your help!
Old Jan 25, 2010 | 01:33 AM
EmperorJJ1's Avatar
cobalt is easier then the cavi... by far (especially coupe v coupe)
theres no rcas anywhere but you can install a LOC in the back where the wires are running to the sub (on top of the sub box then re run speaker wire direct into the stock box. you would need a shallow 10 thou and if ur expecting crazy bass ur not gonna get it out of the stock box
Old Jan 25, 2010 | 06:21 AM
thanks for that, but i was just looking for the rcas to jack into my amp and 12'' sub and box that i've already got...yeah i forgot to mention that i've still got the 12" box and amp that i'm ready to just drop into the trunk. but again thanks for the help!
Old Jan 25, 2010 | 10:48 AM
EmperorJJ1's Avatar
right an LOC (line output converter) is the only way you get rcas in a stock system. stock they dont use rcas they just use locking molex plugs
Old Jan 25, 2010 | 11:36 PM
TCguy's Avatar
https://www.cobaltss.net/forums/how-guide-43/how-upgrade-stock-pioneer-sub-sound-awesome-look-stock-pics-160955/
maybe this will help
Old Jan 25, 2010 | 11:39 PM
scotch89's Avatar
ive seen it done. a girl that had a ss/tc. any way she swaped out the stock sub for a P2 rockford punch sub....i really didnt notice a diff. sounded the same to me.
Old Jan 26, 2010 | 12:43 AM
Originally Posted by TCguy
wow! that is awesome!! thanks for pointing that out!
Old Jan 26, 2010 | 08:21 PM
395 plus's Avatar
I am running my two 12's off the factory amp. The factory sub is a 2 ohm dual voice coil. I took two 12" subs and wired them in parallel to get a 2 ohm load and then hooked it to the Factory amp wiring that I bridged. It definately has more bang than the Single 10". Somewhere down the road I may add an sub amplifier to it.
Old Jan 26, 2010 | 08:51 PM
ThiZo_19's Avatar
395 PLUS THAT LOOKS NICE MAN, surprised u set that **** up on a stock amp...nice work lol
JJ question...if i cut the wires going to the stock sub box...and tape them...and never use them does the amplifier have stronger outputs on the rest of the channels or does that not matter, cuz when i put in my MTX 10''s I ALSO HAVE AN MTX 2 channel AMP, so i dont need any original amp for my subs, but i was wondering if it would make the speakers sound louder/clearer by removing sub. id go outside and do it now, but im in my pjs mannnn
Old Jan 26, 2010 | 10:15 PM
EmperorJJ1's Avatar
no it wouldnt matter because th 6 channel design of the stock amp. but theres a plug on top of the stock box so you can just unplug it instead of cutting the wires
Old Jan 26, 2010 | 10:19 PM
ThiZo_19's Avatar
LOL PWNED thans jj will do when i actually open my trunk and look at it fkn canada winters
Old Jan 26, 2010 | 10:26 PM
EmperorJJ1's Avatar
lol.
Jan 12, 2016 12:01 AM
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
importkiller
Sep 30, 2015 07:18 PM
nathan112i
Sep 30, 2015 07:12 PM
Sep 27, 2015 08:53 PM
