VSS wire?
Old Mar 29, 2008 | 12:33 PM
rrutter81's Avatar
VSS wire?
I looked through all the threads and found 1 with the grey wire from the passenger side kick panel, however it didnt work and seemed to not work for others. Where is the C3 yellow wire at that you guys are using? Is it the horizontal connector in the same area?
thanks
Old Mar 30, 2008 | 09:39 AM
rrutter81's Avatar
Old Mar 30, 2008 | 09:43 AM
Red2.4SS's Avatar
VSS= Vehicle speed sensor. That would be on the transmission.
Is that what you are looking for?
Old Mar 30, 2008 | 09:50 AM
rrutter81's Avatar
Yea but i was hoping i could tap something inside the car instead of routing a wire to the elements.
Old Mar 30, 2008 | 09:54 AM
Red2.4SS's Avatar
There is a VSS output on the ECM I believe. I don't have a pin out for your ECM though. You may be able to find one on here?
Old Mar 30, 2008 | 10:10 AM
BOOSSTED 06's Avatar
under your hood, on your ecm there are three harness, the bottom harness has a yellow wire, tap that wire and your good to go. just slide your intake tube out of the way to get at the wire and harness easy
there is only one yellow wire on that harness, so far its worked on the 05-06, 07 and 08 ive installed avic-d3's on, same wire all cars
Last edited by BOOSSTED 06; Mar 30, 2008 at 10:10 AM. Reason: Automerged Doublepost
Old Mar 30, 2008 | 05:52 PM
rrutter81's Avatar
awesome! thanks guys, my gps was working but the speed sensor always read 0
Old Mar 30, 2008 | 05:57 PM
tombomb's Avatar
contact a user named Zinner
Old Mar 30, 2008 | 07:19 PM
he will tell you the exact same thing i just said
Old Mar 22, 2011 | 02:17 PM
BassAddictJ's Avatar
07 cobalt vss help!?!?!
hey guys. i have a 2007 cobalt and i need to find the vss wire for my avic n5
i located what i think is the ECM, but the there's only 2 harnesses. the bottom one has several yellow wires.....where is the wire i need????
here's a link to an ECM for a 2007 cobalt
2007 Chevy Cobalt LS ECU ECM Computer - Jamison
Here's the ECM in my 07 cobalt
harnesses
bottom harness with 3 or 4 yellow wires
Old Nov 17, 2012 | 09:58 PM
djjefferymichael's Avatar
Hey everyone!
I posted on this awhile ago and unforunately no one replied or was able to help me on this... I'm sure that someone else out there has a Pioneer deck and has had the pink VSS (Variable Speed Sensor) wire up. I have done lots of research on the matter and am leaning towards connecting it to the wiring harness in the ECM.
I have taken the 3 posts below and tried applying them to my install with no success. Possibly Pontiac is different then Chevy when it comes to this type of wiring.
Please see:
https://www.cobaltss.net/forums/elec...s-wire-103906/
Tap VSS for Nav from behind gauge cluster? - Cobalt SS Network
2006 chevy cobalt vss wire - Page 1
I have tried tapping into the YELLOW wire in the bottom harness as recommended with no success. see pic below...
In that 3rd harness note there is a second yellow wire in a twisted pair though. see pic below - note my cam flash washed out the yellow color in that twisted pair but it is plain bright unmarked yellow.... I just feel strongly against using it as its the only wiring clearly paired up with another one (purple).
I have also tried connecting to the only yellow wire in the first harness.
The second harness has 3 solid yellow wires... It may be one of them??? Please anyone help me i'm losing my mind hooking up random yellow wires... Im also worried I will fry something if I keep probing...
ANYONE????
Old Nov 17, 2012 | 10:41 PM
brian.olsson's Avatar
Amazon.com: Axxess XSVI-2103-NAV Non-Amplified Non-OnStar Harness: Car Electronics Amazon.com: Axxess XSVI-2103-NAV Non-Amplified Non-OnStar Harness: Car Electronics
jsut get this instead of cutting into your wireharness,
Old Nov 18, 2012 | 05:52 PM
This is the actual product.. I have a 2007 G5 (not covered)
Axxess XSVI-2103-NAV Non-Amplified Non-OnStar Interface Harness
Compatibility
Chevrolet:
2005-2006 Cobalt
2005-2006 Equinox
2004-2007 Malibu
Pontiac:
2005-2008 G6
2006 Torrent
Old Nov 18, 2012 | 08:23 PM
Compatibility
Chevrolet:
2005-2006 Cobalt
2005-2006 Equinox
2004-2007 Malibu
Pontiac:
2005-2008 G6
2006 Torrent
Yours might.be different, what other options you have, you have onstar, or a Bose or pioneer sound system from the factory, ill find you something
Old Nov 19, 2012 | 02:34 PM
haha awesome!
No onstar, it has the Pioneer premium sound system w/ factory sub etc.
Also note the wiring harness has to have the little converter box w/ the speaker for the chimes and other sounds.
Old Nov 19, 2012 | 06:40 PM
Stereo Radio Wire Wiring Harness Pontiac G5 07 08 2007 2008
this is the only one I could find unfortunally, I"ll keep my eye out and let you know if I find anything cheeper
Old Nov 19, 2012 | 09:13 PM
Thanks for trying
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
dennis69
Oct 20, 2015 07:39 AM
ernnyyes
Oct 2, 2015 05:16 PM
c_m_shooter
Sep 27, 2015 04:40 PM
jmelton327
Sep 26, 2015 10:04 PM
