VSS Wire Really confused
Hello everyone, I have a 2006 Cobalt LS Sedan. I'm installing my AVIC D3 and want to hook up the VSS Wire. I use the Metra 70-2103 harness:
I've heard so many things about the speed sense wire. I've heard that in cobalts it doesn't work. I've heard its the green/white wire on the GM harness. I've heard Its off the transmission module. I've heard the true vss is into the ECU.....Please can someone clarify what to tap into if I can even tap into anything. I understand my D3 doesn't really need it but all possible I would love the little bit of accuracy. Thank you in advance
hey guys this is not the best thing for me to do but check your pm. Call me today, i just finished installing mine wednesday and found the vss wire less then 2 feet away from the head unit and it works perfect
Good job finding the connection. My installers called a buddy they had at GM and did mine today. They say its a purple wire (the only purple wire) located on the tranny mount right beside the exhaust. I didnt look myself but i'll double check that that is the location. They say that there are other secondary wires (which im assuming you tapped into). But from their GM guy that is the "master" vss wire.
yeah i found one in the cabin though, much better, especially to disconnect if ever needed
and no it is not one on the cluster, the one on the cluster is not the best signal
Last edited by BOOSSTED 06; Sep 16, 2007 at 12:03 PM. Reason: Automerged Doublepost
Yea im beginning to think that cuz now my spedometer and in dash computer isnt working properly. Itll work for ablut 10 mins of driving then everything goes nuts. Back to the shop for me.
I hooked into it behind the speedometer and it works just great for me I have the Avic Z1 never had a problem before that I had the Avic D1. Had them in for 2 years now and believe it was a green wire or a green wire with white..
Yea, i told them that but they got their info from their gm guy so i siad whichever they wanted to do. But if they cant fix this problem as it is now ill have them connect it to that one. They did mention however that they were concerned that that connection to the green and white wire wouldnt generate enough power. Oh well. we'll see. got to give them a call tomorrow.
Maybe I don't understand you guys or you don't understand me. I need to know where to connect the VSS wire that is in the lan kit. Were to tap into the vehicles speed signal, inside the car instead of running the wire through the firewall and into the computer harness.
lol if you ahve the gm lan one of the wires coming out of the box should say VSS. tap that on to the vss input for the d3 and done
blue pink wire in the 14 pin harness
http://documents.victorytechnologies...oduct/9022.pdf
