Water leak almost ruined my component speakers
you could also move where the connectors are when you screw the speaker in
The only other option would be to get a set of baffles and cut a hole in the back. Even then thou you might get something weird with the sound. Ive seen it once but a guy made "covers" for the top of the speaker. a sort of umbrellla out of sheet metal to cover the top of the speaker so the water would hit that and drip off the side missing the speaker.
Install Bay VXT60 XTC 6-1/2" Round Large Frame Foam Speaker
^^^ I ordered those. The plan is to plasti-dip the baffles and cut out some holes so the speaker can push air in and out. Doing the install tomorrow hopefully they don't cut my mid bass
Conclusion:
The above baffles did the job but I tested them before tightening everything down and they sounded like ****. The solution was a "3 x "3 square hole facing down so water could drip off without it going into the speakers and I got good sound. Plasti-dip is a no go on foam so scratch that plan.
