Water leak almost ruined my component speakers
Old 01-12-2015, 05:10 PM
UltraSilverSS's Avatar
Exclamation Water leak almost ruined my component speakers
My passenger side speaker stopped working so I tore into the door and found this....
with all the panels off I hosed the door down and it leaked like this......
Any ideas how to stop this leak? Should I buy foam speaker baffles?
Old 01-12-2015, 05:48 PM
chris88z24's Avatar
No car is waterproof in that area. There should be a clear plastic piece behind the speaker that directs water around it.
Old 01-12-2015, 09:31 PM
I had to take off the baffles because the speaker is too big. Seems like the only solution for big speakers would be To buy aftermarket baffles and change them occasionally
Old 01-12-2015, 11:47 PM
cluelessk's Avatar
No, Really?
Old 01-13-2015, 12:54 AM
No, Really?
Huh?
Old 01-13-2015, 03:38 AM
EmperorJJ1's Avatar
mind you if you do any sort of baffles you are going to loose out on sound. So you have to decide between SQ and reliability
Old 01-13-2015, 01:14 PM
You just threw a wrench into my "solution". Any recommendations? The leaks (both doors) are right where the mirror meets the window and the water falls right on the speakers.
Old 01-13-2015, 01:31 PM
cluelessk's Avatar
They're not leaks.
Where else is water from the glass and belt molding supposed to go?
Old 01-13-2015, 02:43 PM
EmperorJJ1's Avatar
The only other option would be to get a set of baffles and cut a hole in the back. Even then thou you might get something weird with the sound. Ive seen it once but a guy made "covers" for the top of the speaker. a sort of umbrellla out of sheet metal to cover the top of the speaker so the water would hit that and drip off the side missing the speaker.
you could also move where the connectors are when you screw the speaker in
Old 01-13-2015, 03:07 PM
They're not leaks.
Not into the doors, just a wild idea
I turned the push terminals to face down. I may have to fab something up something like that
Old 01-25-2015, 11:06 PM
jk0078888's Avatar
I had polk speakers in my calt. They were marine grade. BAM easy fix
Old 01-26-2015, 12:09 AM
Install Bay VXT60 XTC 6-1/2" Round Large Frame Foam Speaker
^^^ I ordered those. The plan is to plasti-dip the baffles and cut out some holes so the speaker can push air in and out. Doing the install tomorrow hopefully they don't cut my mid bass
Old 01-26-2015, 03:23 AM
EmperorJJ1's Avatar
can u plastipip foam?
Old 01-26-2015, 10:30 AM
IDK I'm going to try it.
Old 01-26-2015, 10:34 AM
EmperorJJ1's Avatar
lol u could have got the plastic ones
Old 01-26-2015, 12:26 PM
I couldn't find any that would fit the speakers they have a pretty big magnet structure.
Old 01-30-2015, 11:58 AM
Conclusion:
The above baffles did the job but I tested them before tightening everything down and they sounded like ****. The solution was a "3 x "3 square hole facing down so water could drip off without it going into the speakers and I got good sound. Plasti-dip is a no go on foam so scratch that plan.
Old 02-09-2015, 03:10 PM
EWC88's Avatar
Thanks for posting outcome, need to change speakers in my girlfriends cobalt (finally) and will have to get some baffles.
Old 02-09-2015, 03:30 PM
Cobalt_Daddy's Avatar
my front door speakers are intermittant as well. i'm afraid to tear the doors apart and have a looksee..
Old 02-09-2015, 04:48 PM
EmperorJJ1's Avatar
^^^^ u can do it
biniecki
10-25-2015 02:23 PM
brandon04
10-21-2015 07:04 AM
OrangeCoba
10-01-2015 10:00 PM
Trav3480
10-01-2015 08:17 PM
Quick Reply: Water leak almost ruined my component speakers
