What am I missing?
Old Jul 7, 2013 | 09:07 PM
joepackersrock's Avatar
What am I missing?
I just installed the set of retro's that I've been working on for a couple months. I used a RetrofitSource relay harness and plugged the pigtail labeled "Projector" into the wires that run off the solenoid on the cutoff shield in my Morimoto Mini H1's.
No matter what I do the cutoff shield will not move when I flip on the highbeams, I tried switching the wires on the projector plug with no luck. I get about 11 volts at the projector plug when the high beams are on.
Did both of my solenoids take a crap within the last 2 months or am I overlooking something?
Old Jul 14, 2013 | 10:26 PM
Gixxercobaltdriver's Avatar
I am running into this same issue as well with my retros.. Its dark out by me, but I was going to try and rotating the connectors as well to see if that fixes it... Ill see what kind of voltage I get to.
Old Jul 15, 2013 | 02:00 AM
intel's Avatar
You mentioned you tried switching the wires on the plug, were the wires that you switched the blue/white/beige ones?
There's a certain order that those wires need to be in harness for the high beams to work and there is a way to test your solenoids. I am to lazy to post the pictures as it's late, go to this thread to see what I am talking about:
https://www.cobaltss.net/forums/how-...ics%5D-282150/
If the link doesn't work, search for the thread "FXR" under the "How to Guide" section you'll see what I am talking about.
Old Jul 15, 2013 | 08:12 AM
But, my set up came from buyhids.com I am pretty sure they are already done like this. I think mine will work when I flip the connectors as when I try to flip to high beams they flicker but they dont open.. I bet the polarity is just wrong.
Old Jul 15, 2013 | 05:55 PM
Ok, flopped the connectors, still no go... I am at the same issue. I get voltage at the connector but the solenoids wont flip... So... what does that mean, I am about to jump the wiring harness and us direct battery power to see if it works... any one try this, will I burn up my solenoids if they end up do working but the battery power fries them?
Old Jul 17, 2013 | 07:39 AM
So Joepackersrock, make sure to check the plug on your wiring harness, because I flopped the pins and the high beams worked. everything is working no problem.
Old Jul 17, 2013 | 07:45 AM
mkulrey13's Avatar
almost all TRS 9007 harness's are wired for 9004. Some come swapped some dont. We drop ship so we cannot access them before hand
Issues to look out for:
1. Harness's are wired as 9004. Try swapping the blue/white wires on the harness in the blue plug. Some are different colors and off the top of my head i dont remember which.
2. Some harness's (Mostly early ones) the Projector and ballast wires are mis-labeled. Try swapping
3. Your wires coming from the headlight are backwards in the 9006 plug OR the pins are slightly bent not making a connection.
DarrenGC
Dec 24, 2021 01:55 PM
CobaltSS 16
Sep 29, 2015 01:53 PM
z28addiction
Sep 28, 2015 12:03 AM
Sean Cummings
Sep 11, 2015 09:35 PM
