What do these fuses do?
Old Sep 29, 2008 | 02:37 AM
Ducky22287's Avatar
Sorry if this is dum to ask but I'm not sure exactly what these fuses do..
8 - IGN SW/PK3+
19 - EPS/STR WHL CNTRL
28 - SWC BKLT
Reason it's only these three is because they are 2amps and that's what I need for what I'm doing.
Old Sep 29, 2008 | 03:29 AM
EmperorJJ1's Avatar
ign = ignition
srt whl cntrl = steering wheel control
bklt is probably backlight
you can use a single fuse tap for multiple remotes. infact its easiest to tap from one to another
Old Sep 29, 2008 | 03:39 AM
Ducky22287's Avatar
Well what I'm doing is using an add-a-circuit to wire my radar detector. That can run off a 5amp and the add-a-circuit is rated for a total of 10amps. Unfortunatly where the ignition fuse is I can't use it.
Do you think it'd be safe to use one of the other 2?
Old Sep 29, 2008 | 03:45 AM
EmperorJJ1's Avatar
use sunroof or wiper fuse for the amp remote
Old Sep 29, 2008 | 03:47 AM
Ducky22287's Avatar
The only problem with that is those fuse are 10 or 15 amps and I can only use a total of 10 amps between 2 fuses in this add-a-circuit.
Old Sep 30, 2008 | 01:38 AM
EmperorJJ1's Avatar
the remote turn on for an amp or two is less then 5 amps. and the radar would be on a different fuse. Even on the same fuse the radar shouldnt take alot of juice either
WhineSSbaby
Sep 1, 2020 12:39 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
jmelton327
Sep 26, 2015 10:04 PM
brickloaf
Sep 25, 2015 09:10 PM
shawnsseries
Sep 10, 2015 08:29 PM
