What size amp can I handle
AWD > FWD
I have an old MTX thunder 7124 12" subwoofer. Here is the page with the specs of it
http://www.mtx.com/caraudio/archive/thunderSub7124.cfm
What size amp should I get to get the most power out of it without blowing it? A link to said amp would be much appreciated
Depends on how much money you want to spend
Low price, Plus class A/B so less efficient
http://www.woofersetc.com/p6274/TXi4...-Amplifier.htm
Med price, plus class D so better all around for running subs
http://www.woofersetc.com/p3963/ZX40...-Amplifier.htm
High priced, expensive but it gets the job done and leaves room for upgrade, just don't set the gain top full on it
http://www.woofersetc.com/p6093/T150...-Amplifier.htm
Now that being said, I know people are going to knock me for this but if you want an all around, very effecient, good powered, amp, thry these. I had one running 2 10's and then2 running 2 JL 10w3's and they pounded real nice. The guy I sold them to has them running 4 Rockford Fosgate P2 12's in a Monte Carlo and its loud as hell.
BTW- Not to worry at 4 ohms they put out 424watts, right in your range, heres the link
http://www.woofersetc.com/p235/GTO60...-Amplifier.htm
JBL amps arent bad. **** that hifonics thou. lol spun the only thing ill knock u about that amp is everyone takes off the stupid covers and looses them. then the amp looks like **** sorta like 05 fosgate chrome editions
AWD > FWD
ok quick question to add on, sorry I'm such a noob at subwoofer wiring.
Anyways, I plan on upgrading to a dual suboofer setup soon and have a quick question. I plan on wiring two dual voice coil subs to a mono amp like this
http://akamaipix.crutchfield.com/ca/...4-ohm_mono.jpg
My question is, if the amp I get says 500w RMS x 1, will both subs be getting 500 watts, or will the subs split the power and only get 250w each?
