what wrong with the gauge
Old Jul 24, 2010 | 12:56 AM
09Balt's Avatar
So today i instaled a voltmeter gauge n my car and it was kind of challenging but i got it. but there is one thing iconnected everything to where it should be but how come my gauge isnt reading anything i installed everything right because the gauge lit up and now im not to sure what i did wrong. Does anybody have any idea what i did wrong?
Old Jul 24, 2010 | 01:14 AM
brickloaf's Avatar
there should be 3 wires coming out of the gauge
one goes to ground
one goes to a CONSTANT power source, like the positive battery terminal
and ones goes to a SWITCHED source, you should put this wire in the positive terminal of your amp along with the power wire.
Old Jul 24, 2010 | 01:38 AM
09Balt's Avatar
mine id kind of different it has a bulb that i plug into the anp and the buld has a black and white wire and there are 3 terminal on the bottom of it one has grd, another has S, and the lsat one has I.
Old Jul 24, 2010 | 01:53 AM
brickloaf's Avatar
damn i dont even know then...maybe post a pic or a link to the acctual gauge?
Old Jul 24, 2010 | 01:58 AM
09Balt's Avatar
here is the gauge that i have it sux trust me
http://www.autometer.com/cat_gaugede...id=3111&sid=11
Old Jul 24, 2010 | 02:06 AM
brickloaf's Avatar
yea sorry man i cant help you mine is a digital and im not to sure about the manual ones
Old Jul 24, 2010 | 05:10 AM
Spun's Avatar
The third wire is not used on yours.
You need one to a good ENGINE ground, its very specific in the instructions so I'm thinking a chassis ground might not cut it.
The other has to go to a switched 12 volts source. For this I would use a fuse tap and tap an unused fuse in the fuse box. If you tap a used fuse (wipers, windows, etc) it might have an effect on the gauge when you use whatever you taped.
If you don't have a sunroof then I would use that fuse spot.
I don't suggest using the actual ignition switch, the gauge needs 8 volts at the min to run, but the problem we ran into when installing my remote start is the ignition cycles its voltage, I saw it drop to as low as 1 volt.
Old Jul 25, 2010 | 11:30 AM
09Balt's Avatar
A friend of mine on here hooked it up for me. the ground i used was a bolt under my dash
Old Jul 25, 2010 | 11:44 AM
iboost's Avatar
what he said...
if you look on the installation instructions further down the page...all you use is the ground and the "I" plug. Its too easy...
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
no_ss
Oct 18, 2015 11:58 PM
Sep 27, 2015 08:53 PM
