Where is the best place to ground 4 gauge wire to in the trunk of a balt
Old Jan 26, 2009 | 02:46 PM
TiggeR's Avatar
Old Jan 26, 2009 | 02:49 PM
Sythen1678's Avatar
pick a bolt, or make your own, make sure to strip the paint around where you place your ground.
Old Jan 26, 2009 | 02:51 PM
rockstar014's Avatar
real easy!
Old Jan 26, 2009 | 03:58 PM
megaman311's Avatar
to the battery in the trunk....
beamer1341's Avatar
i grounded to the battery ground next to the battery...
Old Jan 26, 2009 | 04:25 PM
stinkyfisherman's Avatar
what the last two peeps said
Old Jan 26, 2009 | 04:28 PM
hondacrxsi2006's Avatar
I would probably put it a little bit away from your battery actually that way your not going to have to reset any of your presets if the ground wire desides to ground out on the power terminal
Old Jan 26, 2009 | 10:53 PM
Why do that? If its directly to the battery you dont have to worry about any voltage drop due to resistance.
Old Jan 27, 2009 | 12:40 AM
EmperorJJ1's Avatar
ground straight to the battery
06MetallicBalt
Jul 20, 2025 08:47 PM
DarrenGC
Dec 24, 2021 01:55 PM
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
Oct 20, 2015 09:56 PM
c_m_shooter
Sep 27, 2015 04:40 PM
