Why do I have whine...
OK, I have a Clarion HU going to a Kicker KQ9 equalizer then out to an Audio Control Matrix line driver. From there the signal goes to two JL Audio A2150 for the front and rear, and to an MTX TA4501 for the woofer.
With this combo I get real loud whine and hiss through the speakers, especially when I try to adjust the eq levels. So I bypassed the eq and the system sounds really good this way, no whine or hiss, really clear and strong bass. I hooked the eq back up and again really bad alt whine and hiss.
I tried grounding the eq to the chassis and got 12v from the fuse terminals. Still whine and hiss. Do you think there is a problem with the eq? Anyone have problems like this before? Right now the eq is bypassed but since I paid for it I would like to use it. Any help, anyone?
Thanks
Thanks
Don't feel bad your not alone. I went nuts trying to fix mine. The headunit is grounded, both my amps are grounded very well, rca's along one side, power wire from the trunk...
Still get a little whine.
So what should I look for in a HU, what specs should I look at??
Thanks
ok after searching for different eq's and HU I think I found my next stereo, I like the dual L/R 16 band graphic eq feature. It has what I like simplicity of the looks. Not a lot of switches and bright lights. I think this'll do
http://www.pioneerelectronics.com/PU...-P800PRS?tab=B
Anyone wanna buy a Kicker KQ9 EQ lol, jk I'll probably put it another car and see what happens..
Thanks
Thanks
check to make sure everything is properly grounded. If you have a loose/bad ground you'll occasionally get a high pitched whine that fluctuates with the speed of your motor...
BlackBusa24
02-20-2017 08:18 PM
Auddasea
04-16-2009 09:04 PM
