wierd headlight
Old Nov 9, 2009 | 10:09 PM
chitala383's Avatar
wierd headlight
I have gen 1 HID's and for some reason the passengers side low beam wont turn on once in a while. if i turn the headlights off and then back on again it will come on tho. it doesnt do it often but it still annoys me. i know its not the ballast or bulb b/c i just replaced my ballasts and bulbs a few weeks ago. this happened with both sets. any ideas on what the problem could be and how to fix it?
Old Nov 10, 2009 | 08:01 PM
chitala383's Avatar
sooo..... anyone??
ok so now tonight i was messing around w/ my new subwoofer and had the elec on in my car and the headlights were on. out of no where the DIC displayed "service esc" and then my passenger low beam flickered a few times and then went out. i shut the car off and turned it back on and the service esc was gone but the headlight wont come back on now. somebody help!
Last edited by chitala383; Nov 10, 2009 at 08:01 PM. Reason: Automerged Doublepost
Old Nov 11, 2009 | 03:53 AM
Spun's Avatar
Its your wires.
Are you running plug and play or relay harness
Old Nov 11, 2009 | 07:39 PM
chitala383's Avatar
they were plug and play. this morning when i left for work my passenger headlight worked fine. i guess last night was just a fluke of some sort. how would i go about finding out exactly what the problem is with my wiring?
Old Nov 12, 2009 | 04:35 AM
Angel's Avatar
You need to add the relay harness, the plug and play is just garbage because it doesnt send enough current to the ballast that is required for normal operation. Sure it will work alot of the time but you run into issues like you are explaining all the time and with those issues also reduces the lifespan of the ballast. Go out and get those relay harness's asap and I guarantee you dont have anymore issues.
Old Nov 12, 2009 | 09:54 AM
Spun's Avatar
x2
Plus without the relay, HID's tend to burn out stock wires
Go to 3BSpec, in the vendor index, I think the harness is only like $15-20, worth every penny IMO.
Old Nov 12, 2009 | 04:11 PM
chitala383's Avatar
well i did the "ultimate high beams" mod a few months back, and to my understanding u needed a relay harness with the hid's to be able to do this without problems. so i was under the assumption the relay was built in or something. then again i basically know nothing about headlights so im probably wrong. if i do get the relay harness from 3bspec would i have to rewire my ultimate highbeams? what would happen?
Old Nov 14, 2009 | 10:26 PM
chitala383's Avatar
so...................
Old Nov 16, 2009 | 08:00 PM
chitala383's Avatar
how many relay harnesses would i need? would 1 work for both headlights or do i need 2?
Old Nov 19, 2009 | 04:41 PM
chitala383's Avatar
Hellloooo??? Somebody???
Old Dec 10, 2009 | 12:44 AM
Bootz's Avatar
I think this thread may have told me what I need to do fix my HID issue. My issue is that the driver side HID low beam isn't turning on while driving. It does light up however when I lock/unlock the car.
I am the second owner of this car, and the previous owner had these installed. Most likely the stock relay harness buggin' out..
I will be picking up a new harness.. we'll see if this fixes the problem..
cheers =)
Old Dec 10, 2009 | 01:06 AM
outtamymind's Avatar
bootz that sounds like your low beam part of your bulb is burnt out. when you lock/unlock your car it flashes your highbeams. also i would disable that feature as that will shorten the lifespan of the bulbs as from what i've come to understand they don't exactly like being turned on and off so suddenly like that.
Old Dec 10, 2009 | 01:55 AM
Bootz's Avatar
Interesting... thanks for the tip.
If the car has the stock headlights, but upgraded bulbs (not sure on the actual intensity), would you recommend upgrading the harness as these "bright white"bulbs, I have read, tend to suck the life outa the stock harness.
BTW, i just got my 06 ss/sc four days ago.(yaaay!) So forgive me for not knowing the details just yet. I love the way these white lights look. Not a bluish tint at all.
Any suggestions for replacement bulbs or harnesses(if needed)?
Thanks
Old Dec 10, 2009 | 02:37 AM
all depends on whats in there. if they are the silvania bright white bulbs then just put any bulb you choose in and they shouldn't damage anything as long as they are a 9007 35w bulb if im not mistaken. now if you have HID's thats a differen't story all together and all depends on what balast you have installed and what not. and congrats on your purchase. where in edmonton you live?
Old Dec 10, 2009 | 05:37 PM
Bootz's Avatar
Thanks for the help =)
I live in east millwoods.
Didn't notice u were from cowtown till now.. good stuff. I'll have to get your input on any tuner shops near us you could recommend.
Old Dec 10, 2009 | 10:07 PM
ya don't know much but i know matt (cruisn) and i think anomalous tune really well. and ya i got family up there the only area i know is my uncle lives in twin brooks right off the brook. i'll be in leduc this weekend visiting them. you in the regional section so we don't jack OP's thread.
allpro666
Oct 6, 2015 08:11 PM
brickloaf
Sep 21, 2015 02:17 PM
jonnycat
Sep 19, 2015 12:58 PM
QuickSilver_SS
Sep 17, 2015 11:23 AM
