Will a 4' in-dash Nav fit in SS ?
Old May 23, 2006 | 09:11 AM
unknownsoldierX's Avatar
I have a chance to get get a Pioneer AVIC-Z1 for cheap. Accourding to Crutchfield it won't fit in the Cobalt SS. How could I get it in there?
Here's the info on it:
http://www.crutchfield.com/S-Ywc1aFJ...50&I=130AVICZ1
"Note: Your dash must have a 4" opening for the AVIC-Z1 to fit; the 3" openings found in some vehicles, especially GM and Chrysler, will not accommodate it."
Old May 23, 2006 | 09:16 AM
CTSSBowtie's Avatar
ive looked in to the avic's too. although they say it wont fit you should be able to mod the dash yourself or find a car audio place to help you. ive seen pics of 'balts with a double-din system and they look great.
Old May 23, 2006 | 09:51 AM
As long as it's possible, I'll get it. I'll definitely have a shop do it.
Old May 30, 2006 | 11:37 PM
stealththx's Avatar
It is possible but you may have to "modify" a metal bar behind the dash. It is really easy.
Old May 30, 2006 | 11:40 PM
HackAbuse's Avatar
From my personal car Dictionary:
Modify - (verb) - To hack the **** out of, or completely remove a part in order to make way for much better aftermarket parts, or just to make your car more unique/clean.
Old May 30, 2006 | 11:45 PM
HackAbuse's Avatar
Oh and my advice: If you can get it for relatively cheap, GET IT, i just read about this thing and it sounds F***ing amazing, even if i couldnt fit this into my dash, I'd ghetto rig it just because it kicks so much ass!
As with any aftermarket part, my philosophy is ANYTHING can fit into a car with the right elbow grease
Old May 31, 2006 | 02:31 AM
italstalnprd86's Avatar
i can make it fit, and i will put a gaurentee on that.... also can make it stock color to match..... check out my webshots, same username.......
Old Jun 2, 2006 | 07:05 PM
xtremeGM's Avatar
It should fit I have the avic-d1 in my Cobalt SS/SC.( its not in right now becuase I had to get it repaired but I just got it back and will probably reinstall it soon)
Old Jun 2, 2006 | 08:25 PM
stealththx's Avatar
Hahaha. To elaborate on the modifying - Bend the metal bar behind the stereo. You will not be able to see it anyways and it will not affect anything.
Old Jun 3, 2006 | 02:36 AM
i cut mine out.... useless aluminum
Old Jun 3, 2006 | 05:08 AM
Rashnu's Avatar
Actually there are 3 screws/bolts that hold that metal bar in place. i think it was a 7mm head size and you need one of ther wscrew drivers that has a 90degree head on it.
Old Jun 3, 2006 | 04:37 PM
maybe i unbolted it.... i thaught i cut it.. cant remember, it was last year
hacadacalopolis
Oct 28, 2015 06:09 PM
cavfiredesire
Oct 3, 2015 08:02 PM
jmelton327
Wheels and Tires
Oct 2, 2015 01:54 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
Delta coupe
Sep 30, 2015 08:11 AM
