Wire through to engine bay???
Old Jul 14, 2010 | 02:56 PM
JPaLo89's Avatar
Where can I put a wire from the inside of my car to the engine bay??? I want it to look clean and no wires visible...Do I need to drill a hole?!
Old Jul 14, 2010 | 02:59 PM
coopercharge's Avatar
right next to the clutch pedal there is a grommet that has a wire loom that you can push wires thru. there will be a plug that you have to pull out to do so but you can run it thru that grommet and it will be hidden pretty well by the engine dependent on how you run the wires.
Old Jul 14, 2010 | 03:00 PM
DjJoeski87's Avatar
/thread
Old Jul 14, 2010 | 03:06 PM
iboost's Avatar
^agreed
Old Jul 14, 2010 | 03:32 PM
JPaLo89's Avatar
How do you get that plug out? Does it come into the car or into the bay?!
Old Jul 14, 2010 | 03:44 PM
iboost's Avatar
pull it out into your car...its real easy man
What I did was pull the plug thing then I ran a straighten out coat hanger to fish the wires through
Old Jul 14, 2010 | 03:47 PM
PRND3L's Avatar
coathanger is the best way to go! Tape the wire(s) to the hanger and pull them thru.
Old Jul 14, 2010 | 03:58 PM
JPaLo89's Avatar
Ok now....What's the best way to get to the battery from the center console???
Old Jul 14, 2010 | 04:00 PM
iboost's Avatar
haha true that
what are you trying to hook up? Cause I'm sure you don't have to go to the battery. There are a bunch of wires in the dash with 12v on them...
Old Jul 14, 2010 | 04:10 PM
JPaLo89's Avatar
A wolf whistle....I need to mount the whistle somewhere and then get power to it and then to the switch then ground the switch
Old Jul 14, 2010 | 04:15 PM
iboost's Avatar
oh...well, inside your dash there are a few 12v wires. Then for a ground...any metal part of the chassis will be good.
Old Jul 14, 2010 | 04:20 PM
JPaLo89's Avatar
I pulled a yellow clip from behind the clutch, and theres still something blocking it...this is quite frustrating..lol
Old Jul 14, 2010 | 04:25 PM
iboost's Avatar
you can't poke through it?
Old Jul 14, 2010 | 04:27 PM
JPaLo89's Avatar
No, theres something still there where I pulled this yellow clip out from...should that come out too?
Old Jul 14, 2010 | 04:30 PM
asherby85's Avatar
You're making this harder on yourself then it has to be...
Old Jul 14, 2010 | 04:32 PM
Theres no yellow clip to be pulled out does someone have a picture?
its too the left of the clutch pedal and its about 2inched in diameter and it has a flat pluyg in that comes out with a flathead no yellow clip.
Last edited by coopercharge; Jul 14, 2010 at 04:32 PM. Reason: Automerged Doublepost
JPaLo89's Avatar
NVM I found it...I was at the wrong hole...I got it...Thanks!
Old Jul 14, 2010 | 04:43 PM
no problem
Old Jul 14, 2010 | 06:03 PM
Cypher-'s Avatar
I hate it when that happens...
Old Jul 14, 2010 | 06:12 PM
conerboner's Avatar
haha I put it in the wrong hole...
Old Jul 15, 2010 | 03:51 AM
EmperorJJ1's Avatar
the battery is in the trunk... fyi
make sure to put a fuse on whatever wiring your doing too
Old Jul 15, 2010 | 03:52 PM
JPaLo89's Avatar
I wired it to the 12V under the stereo
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
dennis69
Oct 20, 2015 07:39 AM
ernnyyes
Oct 2, 2015 05:16 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
