Wiring diagram for fog lights needed
Are you putting in aftermarkets?
If so I put in Piaa's and used the stock wires, right up to where the stock bulbs would have been, I just sniped a bit of the male spade terminal on the piaa's and pluged it into the stock harness, then used all weather heat shrink (the kind with the silicone in it ) to seal them up. It was almost to easy.
What made up for that being easy was finding a way to mount the new ones, I still have nightmares about it
Yes, I want to replace my current fogs with PIAA lights.
Now I have two cheap chinese fakes with burned out reflectors installed by previous owner. They are simply tapped to low beam wires. Also I can't look to that ugly switch anymore. So I bought stock button, trim piece and dashboard connector. And I plan to spend next Saturday under the car. As I can see, the mountings are almost the same, so the hardest thing for me will be correct electric connections.
