Wiring Harness
Old May 9, 2007 | 06:47 PM
thekingsSS's Avatar
Wiring Harness
I used the search, found some answers, but not all. I have pretty much no knowledge of car audio, and Im getting a new headunit installed. I ran into the problem of no sound coming from the speakers but the headunit did power on. Best Buy told me that the amp couldnt hook up with my RDS cable. So I searched and found that it was probably the wrong wiring harness. If I use this (http://cgi.ebay.com/METRA-70-2103-20...QQcmdZViewItem) wiring harness will my problems be solved? Or is there something I am missing?
Old May 11, 2007 | 08:38 PM
Matrix78's Avatar
what year do you have i have an 07' i just bought that part 70-2103 from CarTunes and it does NOT fit the 2007 Cobalt
on a side note any one know what does fit the 2007?
Old May 11, 2007 | 08:41 PM
SymbioteLT's Avatar
im going to post a link to what you need hold on
https://www.cobaltss.net/forums/electronics-audio-video-49/aftermarket-part-numbers-05-06-cobalts-55035/
Old May 11, 2007 | 09:01 PM
Matrix78's Avatar
thanks for the info
that sux no option but to relocate the radio to the trunk for the 2007, man no love there.
i'll cut the plugs out before i shell out another $200 just to here a ding when my door is open
guess i'll just drive around for a day or 2 without a radio at all plugged in and see if i'm missing anything other than the dings
Old May 11, 2007 | 09:03 PM
SymbioteLT's Avatar
try under the seat?
Old May 11, 2007 | 09:10 PM
blackcopper's Avatar
audio question?
If this is a pioneer set up in your balt, the amp is in the driver kick panel, you can bypass it or you can use a part that integrates the harness in the dash. Either way, make sure you use the remote turn on to the amp turn on or the amp wont turn on to give you sound. Obviously if you bypass the amp, this wont be required since your not using the factory amp. Also if you bypass the amp, the sound will be cleaner, but you may lose the sub in the trunk. When i get to work tomm il get you the right part number if you just wanna use a harness.
Old May 11, 2007 | 09:12 PM
SymbioteLT's Avatar
yes this is for the 05-06 7 speaker pioneer also, no need to bypass
Old May 11, 2007 | 11:38 PM
07blackss86's Avatar
If you have an 07 with the Pioneer system the harness you need is the GMOS-LAN-04. Trust me I got one for mine and it works perfect. I've had my Alpine IVA-W200 for a couple months now, but the harness is pricey.
Old May 11, 2007 | 11:49 PM
Matrix78's Avatar
Well, i have an base 07 LS so stock radio no poineer no sub no amp, and so farI haven't found one of the "cheap" harnesses to use, right now i see no point in paying $100 just to keep a ding when my door is open or my fuel is low.... so i'm going to just cut out the harness thats in there leaving a good amount of wire on the connector end and use quick disconnects on both ends so if need be i could always just reconnect the OEM connectors and radio
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
dennis69
Oct 20, 2015 07:39 AM
ernnyyes
Oct 2, 2015 05:16 PM
jmelton327
Sep 26, 2015 10:04 PM
